Small LCD display help
Did you check with a potentiometer instead of a thermistor?
Also, check if one of the TH pins is directly connected to GND. If it is, try to apply small voltage to the other pin - you can try using a potentiometer connected as voltage divider to the two TH pins and the + pin.
