Hello everyone
i use an olimexino 328 plate and resistive tft 2.8 Adafruit
I read a sensor value and display it on the screen as a line, but the line is very small and I can not see the signal well. Is there any way I can increase the display of the signal?
picture in attache
thank you
//We begin by setting the LED off and reading the signal from the button and the potentimeter for the threshold
potVal = analogRead(potPin);
threshold = potVal -135;
//Next we set the default screen with ECG title and gridlines
//The following displays the ECG title above the grid
tft.setRotation(1);
tft.setCursor(100,0);
tft.setTextColor(ILI9341_WHITE); tft.setTextSize(2);
tft.print(" EKG");
tft.setRotation(0);
countScreen= countScreen+1;
sensorValue = analogRead(ECG);
//When the signal reaches the edge of the TFT screen the cursor is reset and the screen clears
if(countScreen > 320){
countScreen = 0;//start screen at beginning
previouspoint=20;
tft.fillScreen(ILI9341_BLACK);
drawGraph();
//We translate the ECG and Threshold Values to heights on the screen
int thresholdheight=map(threshold, 0, 1023, 0, 300);
//We draw lines for both signal between the previous point and the current point
tft.drawLine(previousThreshold, countScreen-1, thresholdheight, countScreen, ILI9341_RED);
delay (0.000000001);
previousThreshold=thresholdheight;//set previous threshold value
