Small mp3 player breakout board?
Hello,
I tried a wtv020 and it's not that great
  • it's hard to find 2gb sd cards nowadays without getting scamed
  • and although I followed all steps to convert my files to AD4 file format, the result is not that great
  • also ad4 is proprietary and obsolete afaik
so I am looking for a small footprint mp3 breakout board reader for my projects
any help ?
thanks
Do you mean something like a DFPlayer Mini?
I found 16GB micro SD cards were cheaper than 8GB and lower so I use those. DFPlayer can be controlled by an Arduino or operate as a standalone. Pretty small too.
thx I'll check it out
If you go with the DFPlayer Mini option, then try to get the one that uses a YX5300/YX6300 IC to avoid headaches with library compatibility.
Couple other options I've ran across & bought, but haven't used them yet:
GPD2846A - slightly larger, less features
GPD2856C - larger but more stuff on the board like USB, buttons, speaker terminal, headphone jack
WT588D-20SS (16U or 32U) - Doesn't have an SD Card slot, but does have 16MB (-16U) or 32MB (-32U) of onboard storage
