small problem
I have a problem in my code, but what?
my button does not work
 #include "pitches.h"
int melody[] = {
  NOTE_C4, NOTE_G3,NOTE_G3, NOTE_A3, NOTE_G3,0, NOTE_B3, NOTE_C4};
int noteDurations[] = {
  4, 8, 8, 4,4,4,4,4 };
int switchState =0;
pinMode(2, INPUT);
switchState = digitalRead(2);
if (switchState == HIGH) {
  for (int thisNote = 0; thisNote < 8; thisNote++) {
    int noteDuration = 1000/noteDurations[thisNote];
    tone(8, melody[thisNote],noteDuration);
    int pauseBetweenNotes = noteDuration * 1.30;
    delay(pauseBetweenNotes);
    noTone(8);
else {
Is the button connected to the right pin? do you have a voltmeter to check that?
if you remove the button test from the code does it do as expected?
Sorry i'm a beginner, what is a button "test"?
Button test.
Yes, without the button test, it works.
Make these changes:
Connect the switch so when closed, the pin connects to Gnd.
Enable the internal pullup resistor: pinMode(2, INPUT_PULLUP);
Test to see to if button is pressed and the pin connected to Gnd: if (switchState == LOW) {
Dont work:
int melody[] = {
int switchState =0;
    noTone(8);
else {
Add this line into setup()
Serial.begin(9600)
Add these lines right after the tone() statement.
      Serial.print(melody[thisNote]);
      Serial.print(" ");
      Serial.println (1000/noteDurations[thisNote]);
It works for me. I didn't have a speaker handy to test with, but the Serial.print statements show me that the code is executing as it should.
this is the output:
262 250 196 125 196 125 220 250 196 250 0 250 247 250 262 250
Just to clarify, your switch shoule be wired as follows:
GND____/ ____Pin 2
