small project
hello,
i have a problem with me code, i want to let the buzzer play a tone when the ir recieves a code. the problem is every time i use the code tone(buzzer,1000); for example he cant compile the file for arduino uno.
this is the faultmessage:
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board:“Arduino Uno”
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port’:
(.text+0x0): multiple definition of `__vector_7’
libraries\IRremote-2.2.3\IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Fout bij het compileren voor board Arduino Uno
Dit rapport zou meer informatie bevatten met
“Uitgebreide uitvoer weergeven tijden compilatie”
optie aan in Bestand → Voorkeuren.
kamer_papa.ino (514 Bytes)
if you type `timer0_pin_port' into a google search you get lots of hits giving information about this.
Basically two bits of code (libraries maybe) are trying to set the same timer.
With a bit more reading you may find solutions to the problem there.
Peter
