I have no suggestion as far as a smaller SD library, but would be interested if you find one. Have you used all the SRAM conserving tricks already. Like the F macro, using PROGMEM and making variables const when possible? Local instead of global variables?
groundFungus:
The problem seems to be a lack of program space rather than a shortage of SRAM, If program space is at a premium maybe it would be a good idea NOT to use the F macro or PROGMEM
Robin2:
sgt_johnny:
Yes, the problem is the display library, SPI, and the GPS Library are using most of the space, the display library takes 11kb of the 28kb...
You can't blame the display library, the real problem is simply too many libraries. And even if you did squeeze them in, you might still be faced with the uncertainty of reliable running. It might be time to think about getting a Mega because the is one thing you can be pretty sure of - the problem you have now is likely to get worse. Reason: the chances of you thinking about some thing you want to add next week, that you didn't know about last week, are pretty good.
Mega is not a option, since my board with all the stuff is already soldered And yes, i need a File, to write down gps and data and then read in on computer...
I now try to make way for 7% program space...
Yes too many libraries, but the display "steals" around 50%, the other libraries only take around 25% (SPI,NeoGPS), images and my code take around 7%
If someone is interested, i can upload to github..
sgt_johnny:
And what about uploading by another Arduino reading the raw data from the storage? Or another Arduino reading data from the easy storage and rewritig them to a file on SD card?
sgt_johnny:
So as the Mega is 'not an option', do you think some other solution will appear as if by magic ?
If your project is using a display, GPS and SD card then runs out of program space big time, you need to accept reality, you need an Arduino such as the Mega (or 1284P) that is 'not an option'
I would also make a suggestion, dont decide on or commit to the hardware design until the software is actually working.
