Hi
I'm working on a small project to display actual time with date and two departure times from a online timetable.
Steps:
get time
get timetable information via curl
display time/date and two departures times
Also I have not so much program storage space left.
Sketch uses 28,080 bytes (97%) of program storage space. Maximum is 28,672 bytes.
Global variables use 863 bytes (33%) of dynamic memory, leaving 1,697 bytes for local variables. Maximum is 2,560 bytes.
here the code what I have right now:
#include <Process.h>
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#define MAX_ZONES 2
#define ZONE_SIZE 5
#define MAX_DEVICES (MAX_ZONES * ZONE_SIZE)
#define ZONE_UPPER 1
#define ZONE_LOWER 0
#define CLK_PIN 11
#define DATA_PIN 12
#define CS_PIN 10
MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
char dep1[8];
char dep2[8];
int seconds;
int lastSecond = -1;
String timeStamp;
String dateStamp;
String ts;
Process pc; // process for curl, used to get timetable information
Process date; // process used to get time
Bridge.begin(); // Initialize Bridge
Serial.begin(57600);
while (!Serial);
Serial.println("Start Setup");
P.begin(MAX_ZONES);
P.setZone(ZONE_LOWER, 0, ZONE_SIZE - 1);
P.setZone(ZONE_UPPER, ZONE_SIZE, MAX_DEVICES - 1);
Serial.println("End Setup");
getTime();
getDepartures();
toMatrix();
String urlDecode(String urlChars) {
urlChars.replace("[", "%5B");
urlChars.replace("]", "%5D");
urlChars.replace("ä", "%C3%A4");
return urlChars;
void getDepartures() {
char jsonResponse[200];
String url = "http://transport.opendata.ch/v1/connections?from=Kräyigen&to=Bern&limit=2&fields[]=connections/from/departure&time=" + ts;
Serial.println(url);
pc.begin("curl");
pc.addParameter(" - H \"Cache-Control: no-cache\"");
pc.addParameter(urlDecode(url));
pc.run();
// response
int i = 0;
while (pc.available() > 0) {
char c = pc.read();
jsonResponse[i] = c;
i++;
char *ptr; // temp pointers
char *fieldPtr; // temp pointers
// get departure time 1
ptr = strstr(jsonResponse, "T");
if (ptr != NULL) {
ptr++;
fieldPtr = ptr;
ptr = strstr(ptr, "+");
ptr = '\0';
strcpy(dep1, "1. ");
strncat(dep1, fieldPtr, 5);
// get departure time 2
ptr = strstr(fieldPtr, "T");
if (ptr != NULL) {
ptr++;
fieldPtr = ptr;
ptr = '\0';
strcpy(dep2, "2. ");
strncat(dep2, fieldPtr, 5);
void getTime() {
Serial.println("get time ...");
if (lastSecond != seconds) {
if (!date.running()) {
date.begin("date");
date.addParameter("+%d.%m.%y %T");
date.run();
while (date.available() > 0) {
timeStamp = date.readString();
timeStamp.trim();
dateStamp = timeStamp.substring(0, 8);
timeStamp = timeStamp.substring(9, 17);
int secondColon = timeStamp.lastIndexOf(":");
String secString = timeStamp.substring(secondColon + 1);
lastSecond = seconds;
seconds = secString.toInt();
ts = timeStamp.substring(0, 5); // timestamp needed for curl query
void toMatrix() {
char charBuf[6];
ts.toCharArray(charBuf, 6);
P.displayZoneText(ZONE_LOWER, charBuf, CENTER, 40, 5000, SCROLL_DOWN, SCROLL_UP);
P.displayZoneText(ZONE_UPPER, dep1, CENTER, 40, 5000, SCROLL_DOWN, SCROLL_UP);
// synchronise the start and run the display to completion
P.synchZoneStart();
while (!P.getZoneStatus(ZONE_LOWER) || !P.getZoneStatus(ZONE_UPPER))
P.displayAnimate();
char charBuf2[9];
dateStamp.toCharArray(charBuf2, 9);
P.displayZoneText(ZONE_LOWER, charBuf2, CENTER, 40, 5000, SCROLL_UP, SCROLL_DOWN);
P.displayZoneText(ZONE_UPPER, dep2, CENTER, 40, 5000, SCROLL_UP, SCROLL_DOWN);
P.synchZoneStart();
P.displayAnimate();
The time/data part is working. The curl part itself is also working.
I have some problem with read out of the departure times.
Curl is running the url and the response is as follows:
"connections": [{
"from": {
"departure": "2016-01-05T15:53:00+0100"
"from": {
"departure": "2016-01-05T15:54:00+0100"
from this json I need just the timestamp ->15:53 and 15:54
When I upload the whole sketch noting will display on the LED Matrix. When I uncomment the block
and
then the time and date on the LED matrix is shown.
Some one has an idea how to optimize the part to read out the time?
THX
Pascal
