Smaller Arduino?
Is there a really cheap and small version of and arduino i can get. Im thinking less than $15 and really small? Have any ideas?
Arduino Pro Mini from Sparkfun. $19 Bare Bones Board, and Really Bare Bones Board KITS from Modern Device Co. ($15, $12)
These will all require a separate USB/Serial cable at about $20, but it can be used with multiple boards.
Cheapest is to build your own serial version from scratch (~$5 for a pre-programmed AVR, plus junkbox parts (more or less)), but that adds considerably to the level of expertise required to get started. A smaller Serial Arduino would be an interesting project... (Tough, too. You'll note that all of the existing single-sided Serial Arduinos had to make the board bigger to fit everything on...)
Well, the main question I'd have to ask is do you already have an arduino? (an NG/Diecimila)
If you do, you can make a really tiny (about the size of the Atmega) and use the NG/Deicimila to program it)
For the basic circuitry go here: http://itp.nyu.edu/physcomp/Tutorials/ArduinoBreadboard
Just follow steps one and two.
When you solder it all up, be sure to use a dip-28 instead of soldering the atmega in so that you can pop it out for programming.
I already have an arduino, i was thinking of like integrating it into an ornithopter to contorol it, thanks,
yea like asp said u can basically adapt the breadboard setup like here:
http://www.instructables.com/id/uDuino-Very-Low-Cost-Arduino-Compatible-Developme/%20#allsteps
i have used this method to make a homebrew mini board based on a lilipad bootloader, works a charm and i program it with a home made rs232 to ttl converter.
