I'm building a surround sound speaker system with an Arduino, but want to know if there's a really small Arduino version i don't know about with at least 20 pinouts?
Arduino Nano e.g.
How small?
The m328 in a 32CC1 or 28M1 package is 4mm by 4mm. You will be hard pressed to find a 20 pin anything in a smaller package.
There was http://staging.femtoduino.com/
It doesn't look like it is available as a product, but the design files are supposedly published.
If you don't need it quite that small, there are a lot of "Arduino Nano" (with USB) and "Arduino Pro Micro" (with FTDI Serial connector) boards available that are still quite compact compared to the original Arduino.
I offer a small card, 1.3" x 1.3", no regulator or USB connector.
But a $3 promini will do the same at ~1.2" x ~.7"
and a Nano is not much larger
and both are less than I pay just for parts.
I just bought 5 of the promini's, they say Deek Robot on the back and look to be well manufactured for a simple 328 and resonator, button, and a couple Rs & Cs. They don't have the extra power & gnd signals of mine, so will not be quite as convenient to use.
CrossRoads:
Also you have mounting holes. If you're not going to socket the Arduino into another board via headers, mounting holes are such a plus imo.
Geoff
CrossRoads:
No crystal?
Paul__B:
No crystal?
The crystal is on the underside of those boards. The boards in that picture were built by me using CrossRoads PCBs. I wish I would have positioned one board upside down.
I currently have three boards that I have used for projects. The extra grounds really help when powering lots of LEDs!
Mark
I've used many of those cheap units; never a dud. They also work well (yes, I know the caveats) at 3.3V. Mount to the back of a 2.2" 320x240 GLCD with double-stick tape.
Ray
