Smallest stepper library?
I'm looking for the smallest, simplest stepper library available, I pretty much need only STEP and DIR pin assignment, no microstopping, no EN/RESET/FAULT... pins or anything like that, it's gonna be used with an ATTiny (the reason it needs to be small) and a DRV8824 stepper driver, I just need to rotate the stepper an amount of steps or constantly until stopped by a sensor.
Thanks
Oscar
Why do you need a library to set the direction pin HIGH or LOW, and to trigger the step pin? Take a look at the Stepper library, to see how it actually makes a step happen. The only other thing that it does is manage WHEN the step(s) happen.
Have you googled attiny stepper
Tom... :slight_smile:
