Hi all, I am not very good at Arduino but I can get something out. I am currenlty messing around with smart batteries from my drone DJI mini 2. I found a code to get battery parameters and next spet would be to change some of them reason being replacement of internal akkus. The value that I need to change is the cycli counter. So far my understanding is that the value is stored into a specific memory location, so I wonder how I could write the new value. Following two codes, first one for reading (tested and working), second one for write (yet to test). Any help would be much appreciated.
reading sketch
* SMBus FOR 3DR SOLO with Arduino UNO R3
* STAVROPOULOS
* Code Version 0.02 beta
* MUCH OF THIS CODE WAS COPIED FROM
* https://github.com/PowerCartel/PackProbe/blob/master/PackProbe/PackProbe.ino
* https://github.com/ArduPilot/PX4Firmware/blob/master/src/drivers/batt_smbus/batt_smbus.cpp
* Configured for Arduino UNO R3
* you will need to use external pull up resistors of
* 4.7k-ohm to pull the SDA and SCL lines up to 3.3v
* CONFIGURE I2C/SERIAL ON ARDUINO
//DEFINE SDA AND SCL PINS
#define SCL_PIN 5 // ARDUINO UNO PIN A5 - COMMUNICATION PIN 5 ON MEGA
#define SCL_PORT PORTC
#define SDA_PIN 4 // ARDUINO UNO PIN A4 - COMMUNICATION PIN 6 ON MEGA
#define SDA_PORT PORTC
//CONFIGURE I2C MODES
#define I2C_TIMEOUT 100 //PREVENT SLAVE DEVICES FROM STRETCHING LOW PERIOD OF THE CLOCK INDEFINITELY AND LOCKING UP MCU BY DEFINING TIMEOUT
//#define I2C_NOINTERRUPT 1 //SET TO 1 IF SMBus DEVICE CAN TIMEOUT
//#define I2C_FASTMODE 1 //THE STANDARD I2C FREQ IS 100kHz. USE THIS TO PERMIT FASTER UP TO 400kHz.
//#define I2C_SLOWMODE 1 //THE STANDARD I2C FREQ IS 100kHz. USE THIS TO PERMIT SLOWER, DOWN TO 25kHz.
#define BAUD_RATE 9600
#include <SoftI2CMaster.h>
* CONFIGURE SERIAL LIBRARY
//#include <SoftwareSerial.h>
//#include <Serial.h>
#include <Wire.h>
* DEFINE VARIABLES AND SMBus MAPPINGS
#define BATT_SMBUS_ADDR 0x0B ///< I2C address
#define BATT_SMBUS_ADDR_MIN 0x08 ///< lowest possible address
#define BATT_SMBUS_ADDR_MAX 0x7F ///< highest possible address
//BUS MAPPINGS FROM DEV.3DR
#define BATT_SMBUS_TEMP 0x08 ///< temperature register
#define BATT_SMBUS_VOLTAGE 0x09 ///< voltage register
#define BATT_SMBUS_REMAINING_CAPACITY 0x0f ///< predicted remaining battery capacity as a percentage
#define BATT_SMBUS_FULL_CHARGE_CAPACITY 0x10 ///< capacity when fully charged
#define BATT_SMBUS_DESIGN_CAPACITY 0x18 ///< design capacity register
#define BATT_SMBUS_DESIGN_VOLTAGE 0x19 ///< design voltage register
#define BATT_SMBUS_SERIALNUM 0x1c ///< serial number register
#define BATT_SMBUS_MANUFACTURE_NAME 0x20 ///< manufacturer name
#define BATT_SMBUS_MANUFACTURE_DATA 0x23 ///< manufacturer data
#define BATT_SMBUS_MANUFACTURE_INFO 0x25 ///< cell voltage register
#define BATT_SMBUS_CURRENT 0x2a ///< current register
#define BATT_SMBUS_MEASUREMENT_INTERVAL_US (1000000 / 10) ///< time in microseconds, measure at 10hz
#define BATT_SMBUS_TIMEOUT_US 10000000 ///< timeout looking for battery 10seconds after startup
#define BATT_SMBUS_BUTTON_DEBOUNCE_MS 300 ///< button holds longer than this time will cause a power off event
#define BATT_SMBUS_PEC_POLYNOMIAL 0x07 ///< Polynomial for calculating PEC
#define BATT_SMBUS_I2C_BUS PX4_I2C_BUS_EXPANSION
//BUS MAPPINGS FROM SMBus PROTOCOL DOCUMENTATION
#define BATTERY_MODE 0x03
#define CURRENT 0x0A
#define RELATIVE_SOC 0x0D
#define ABSOLUTE_SOC 0x0E
#define TIME_TO_FULL 0x13
#define CHARGING_CURRENT 0x14
#define CHARGING_VOLTAGE 0x15
#define BATTERY_STATUS 0x16
#define CYCLE_COUNT 0x17
#define SPEC_INFO 0x1A
#define MFG_DATE 0x1B
#define DEV_NAME 0x21 // String
#define CELL_CHEM 0x22 // String
#define CELL4_VOLTAGE 0x3C // Indidual cell voltages don't work on Lenovo and Dell Packs
#define CELL3_VOLTAGE 0x3D
#define CELL2_VOLTAGE 0x3E
#define CELL1_VOLTAGE 0x3F
#define STATE_OF_HEALTH 0x4F
//END BUS MAPPINGS
#define bufferLen 32
uint8_t i2cBuffer[bufferLen];
// standard I2C address for Smart Battery packs
byte deviceAddress = BATT_SMBUS_ADDR;
//INITIATE SERIAL CONSOLE
Serial.begin(BAUD_RATE);
Serial.println(i2c_init());
//SETUP I2C INPUT PINS
//pinMode(27,INPUT_PULLUP); //use external pull up resistor instead
//pinMode(28,INPUT_PULLUP); //use external pull up resistor instead
Serial.flush();
while (!Serial) {
; //wait for Console port to connect.
Serial.println("Console Initialized");
i2c_init(); //i2c_start initialized the I2C system. will return false if bus is locked.
Serial.println("I2C Inialized");
scan();
int fetchWord(byte func)
i2c_start(deviceAddress<<1 | I2C_WRITE); //Initiates a transfer to the slave device with the (8-bit) I2C address addr.
//Alternatively, use i2c_start_wait which tries repeatedly to start transfer until acknowledgment received
//i2c_start_wait(deviceAddress<<1 | I2C_WRITE);
i2c_write(func); //Sends a byte to the previously addressed device. Returns true if the device replies with an ACK.
i2c_rep_start(deviceAddress<<1 | I2C_READ); //Sends a repeated start condition, i.e., it starts a new transfer without sending first a stop condition.
byte b1 = i2c_read(false); //i2c_read Requests to receive a byte from the slave device. If last is true,
//then a NAK is sent after receiving the byte finishing the read transfer sequence.
byte b2 = i2c_read(true);
i2c_stop(); //Sends a stop condition and thereby releases the bus.
return (int)b1|((( int)b2)<<8);
uint8_t i2c_smbus_read_block ( uint8_t command, uint8_t* blockBuffer, uint8_t blockBufferLen )
uint8_t x, num_bytes;
i2c_start((deviceAddress<<1) + I2C_WRITE);
i2c_write(command);
i2c_rep_start((deviceAddress<<1) + I2C_READ);
num_bytes = i2c_read(false); //num of bytes; 1 byte will be index 0
num_bytes = constrain(num_bytes,0,blockBufferLen-2); //room for null at the end
for (x=0; x<num_bytes-1; x++) { //-1 because x=num_bytes-1 if x<y; last byte needs to be "nack"'d, x<y-1
blockBuffer[x] = i2c_read(false);
blockBuffer[x++] = i2c_read(true); //this will nack the last byte and store it in x's num_bytes-1 address.
blockBuffer[x] = 0; // and null it at last_byte+1
i2c_stop();
return num_bytes;
void scan() // cerca la batteria
byte i = 0;
for ( i= 0; i < 127; i++ )
Serial.print("Address: 0x");
Serial.print(i,HEX);
bool ack = i2c_start(i<<1 | I2C_WRITE);
if ( ack ) {
Serial.println(": OK");
Serial.flush();
else {
Serial.println(": -");
Serial.flush();
i2c_stop();
delay(10000);
uint8_t length_read = 0;
Serial.print("Manufacturer Name: ");
length_read = i2c_smbus_read_block(BATT_SMBUS_MANUFACTURE_NAME, i2cBuffer, bufferLen);
Serial.write(i2cBuffer, length_read);
Serial.println("");
Serial.print("Manufacturer Data: ");
length_read = i2c_smbus_read_block(BATT_SMBUS_MANUFACTURE_DATA, i2cBuffer, bufferLen);
Serial.println("");
Serial.print("Manufacturer Info: ");
length_read = i2c_smbus_read_block(BATT_SMBUS_MANUFACTURE_INFO, i2cBuffer, bufferLen);
Serial.println("");
Serial.print("Design Capacity: " );
Serial.println(fetchWord(BATT_SMBUS_DESIGN_CAPACITY));
Serial.print("Design Voltage: " );
Serial.println(fetchWord(BATT_SMBUS_DESIGN_VOLTAGE));
Serial.print("Serial Number: ");
Serial.println(fetchWord(BATT_SMBUS_SERIALNUM));
Serial.print("Voltage: ");
Serial.println((float)fetchWord(BATT_SMBUS_VOLTAGE)/1000);
Serial.print("Full Charge Capacity: " );
Serial.println(fetchWord(BATT_SMBUS_FULL_CHARGE_CAPACITY));
Serial.print("Remaining Capacity: " );
Serial.println(fetchWord(BATT_SMBUS_REMAINING_CAPACITY));
Serial.print("Temp: ");
unsigned int tempk = fetchWord(BATT_SMBUS_TEMP);
Serial.println((float)tempk/10.0-273.15);
Serial.print("Current (mA): " );
Serial.println(fetchWord(BATT_SMBUS_CURRENT));
Serial.print("Device Name: ");
length_read = i2c_smbus_read_block(DEV_NAME, i2cBuffer, bufferLen);
Serial.println("");
Serial.print("Chemistry ");
length_read = i2c_smbus_read_block(CELL_CHEM, i2cBuffer, bufferLen);
Serial.println("");
String formatted_date = "Manufacture Date (Y-M-D): ";
int mdate = fetchWord(MFG_DATE);
int mday = B00011111 & mdate;
int mmonth = mdate>>5 & B00001111;
int myear = 1980 + (mdate>>9 & B01111111);
formatted_date += myear;
formatted_date += "-";
formatted_date += mmonth;
formatted_date += mday;
Serial.println(formatted_date);
Serial.print("Specification Info: ");
Serial.println(fetchWord(SPEC_INFO));
Serial.print("Cycle Count: " );
Serial.println(fetchWord(CYCLE_COUNT));
Serial.print("Relative Charge(%): ");
Serial.println(fetchWord(RELATIVE_SOC));
Serial.print("Absolute Charge(%): ");
Serial.println(fetchWord(ABSOLUTE_SOC));
Serial.print("Minutes remaining for full charge: ");
Serial.println(fetchWord(TIME_TO_FULL));
// These aren't part of the standard, but work with some packs.
// They don't work with the Lenovo and Dell packs we've tested
Serial.print("Cell 1 Voltage: ");
Serial.println(fetchWord(CELL1_VOLTAGE));
Serial.print("Cell 2 Voltage: ");
Serial.println(fetchWord(CELL2_VOLTAGE));
Serial.print("Cell 3 Voltage: ");
Serial.println(fetchWord(CELL3_VOLTAGE));
Serial.print("Cell 4 Voltage: ");
Serial.println(fetchWord(CELL4_VOLTAGE));
Serial.print("State of Health: ");
Serial.println(fetchWord(STATE_OF_HEALTH));
Serial.print("Battery Mode (BIN): 0b");
Serial.println(fetchWord(BATTERY_MODE),BIN);
Serial.print("Battery Status (BIN): 0b");
Serial.println(fetchWord(BATTERY_STATUS),BIN);
Serial.print("Charging Current: ");
Serial.println(fetchWord(CHARGING_CURRENT));
Serial.print("Charging Voltage: ");
Serial.println(fetchWord(CHARGING_VOLTAGE));
Serial.println(fetchWord(CURRENT));
Serial.println(".");
delay(20000);
CODE FOR WRITING
#include <Wire.h>
#define I2C_ADDRESS 0x58 // address della batteria
#define REG_CURRENT 0x17 // register address
Wire.begin();
delay(100);
byte currentValue = 0x01;
Wire.beginTransmission(I2C_ADDRESS);
Wire.write(REG_CURRENT);
Wire.write(currentValue);
Wire.endTransmission();
void loop() {}
