Smart soccer gate with RFID
I want to build an amateur soccer goal with the ability to identify the ball that passes through the gateway use with RFID tag On the ball .
Does anyone have an idea or experience in this case?
Would RFID be fast enough to read a tag on a fast moving ball?
There is also the question of the distance from the ball to the reader.
...R
time delay is n't important, distance is around 20 cm.
keyvan_h:
I'm not a sports person but any goal posts that I have seen are much wider than 20cm
I don't know what you have in mind with "time delay". How long will the ball be within range of a sensor? And if the sensor can detect the ball at long rang won't it be a lot less precise?
A diagram of that you have in mind would help. See this Simple Image Guide
...R
the simple image is attached
Please make your image visible. I gave you a link to the instructions.
...R
