I checked connections and shorts, all seems to be well.
I flashed it with another arduino using ArduinoISP. While burning the bootloader the TX and RX leds on the programming arduino-board flash happily and my IDE ends with a remark like "bootloader has been burned". All seems well.
After that I proceeded to flash my new chip with a sparkfun ftdi breakout board. This board works well with other standalone atmega328 chips. When I try to upload a program only the TX led on the sparkfun board flickers, not the RX, and I get this error message:
Binary sketch size: 466 bytes (of a 30,720 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
I did try and swap TX and RX lines just to check if I mixed those up, to no avail.
I'm pretty much at a loss here: I do not now if my chip works. My questions would be along these lines:
my IDE reports the bootloader has been burned. Is it possible the process went wrong but I still get this remark ?
can I be confident that my crystal is working well ? can you burn a bootloader with a malfunctioning crystal ? Most sync-errors with other standalone boards were cause of wrong capacitors on the crystal.
You might have wrong baud-rate or issues with the ftdi-driver.
Have you tried the loopback-test with the serial monitor?
FTDI board only at first, than test it with the arduino.
Loop-back test with just the ftdi board works fine, the serial monitor in the IDE echoes everything. If the board is connected to the smd chip and I connect TX and RX the loop-back still works.
Try
File:Preferences , click the Verbose output check boxes, see what comes up.
If no errors, then see if you can upload a sketch via the ICSP connections (File:Upload Using Programmer).
If that works, then the error may be speed mismatch between what the PC is using and what the bootload code is using.
I'll have to wait a few days because the chip burned, so I'll have to replace it or make a new board.
To clarify: I tried to burn a bootloader TO the atmega328 smd chip, using a regular Arduino UNO board as ISP programmer.
I put the ArduinoISP sketch onto the UNO, connected the smd chip according to the ArduinoISP pages on the website (http://arduino.cc/en/Tutorial/ArduinoISP) and tried to burn the bootloader to the smd chip. There is one thing I did not really understand:
Wire your Arduino board to the target as shown in the diagram below. (Note for the Arduino Uno: you'll need to add a 10 uF capacitor between reset and ground.)
So I need to put the 10uF between reset and GND of the device that is using the ArduinoISP sketch, or on the target ?
As far as I know I tried to burn the standard bootloader; I use IDE version 1.0.3 I think, so the bootloader that comes with that.
