MarkT:
I'd just do a parametric search for the cheapest device matching my requirements - there are thousands of MOSFETs on the market, changing all the time.
You can get 6-pin dual MOSFETs with one p-channel and one n-channel device - then you only need one device "in-stock" for all these uses.
You need a free-wheel diode to switch an inductive load safely. The diode protects the switch.
Thank you for your reply! The thing is, when doing a parametric search i just have too many options. As i have little experience with SMD MOSFETs it can be hard to chooose.
wvmarle:
NMOS: PMV16XN (8A or so, very low RDS, ON), IRLML2502 (5A or so), BSS138 (small signal switching). All these I primarily picked for switching properly at 3.3V VGS.
PMOS: IRLML6401 (3-4A or so); BSS170 (small signal switching).
For details on these MOSFETs refer to the respective data sheets.
Thanks for your suggestions. The PMV16XN has a ver nice low Rds(on) indeed, but its much more expensive, and has a Vds of only 20V. The other N-fets you mention seem to be more expensive then the dirt cheap AO3400A without offering much better specs. The PMV16XN may be interesting though.
MarkT:
Be aware that current ratings for MOSFETs are not normally useful. The on-resistance and power dissipation are much more useful.
Usually current maximum is under the assumption of infinite heatsink, ie it is not a practical rating for real-world use, but a theoretical one. If you happen to have water-cooled heatsink it becomes realistic, but that's unlikely!
For a small package you might be limited to, say, 0.1W dissipation, in which case a 50 milliohm device can handle 1.4A, or a 10 milliohm device about 3A. Power = I-squared-R
You may have a good point here. For previous trough hole projects is always just grap a overpowered mosfet in TO220, but for these small devices i may need to take dissipation into account.
I'm guessing heat can be a real problem for high frequency PWM application, and i would really need a lower Rds(on) and a fast switching FET.
larryd:
These work well:
AO4419 SOP-8 SMD P-Channel
AO4614 SOP-8 4614 N/P-Channel
AO4484 SOP-8 4484 N-Channel
Those also loook interesting. A little larger package which is not always ideal, but for the P-fet the Rds(on) seems very low. They are not as dirt cheap as the AO3400A however, and it seems like they will not work perfectly on a Vgs of 3V, but 5V seems fine. The larger package seems to allows for more heat dissipation, so this one might be very suitable for higher power applications.
wvmarle:
I normally calculate the limits at 250 mW dissipation. I do expect the PCB it's mounted on to help out, especially as I normally place the ground plane on top (also gives much easier connection of the drains - of course no thermal relief there).
I think you are right, and i need to take the power dissipation into account. If i look at the AO3400A datasheet i only see a maximum rating of approx 1W. Is 1/4th of that a rule of thumb for realistic dissipation?
If so a AO3400A would be able to handle 2.8A which is still plenty for most applications i have in mind, or am i missing something?
All of these suggestions are very useful for me for both current applications and future applications!
