SMD N Channel MOSEFET
THIS IS THE N channel MOSFET that I came up with. I think it will work well with my Arduino project. Can someone verify that it will work well as a switch, from an Arduino pin. Here is my schematic. Vcc is 6 volts from 4 AA batteries.
It will be powering a small 6 volt vibrator, 100mA.
Thanks.
Yes, its logic level - you can use it as a low-side switch.
