smiple "calcuation" problem?
Hello, i am working on a simpe servo code using array. Here is a small part of the code, I hope it does not matter that it is not full yet. I have the "variables" (is that the right name?) "nr1" and "nr2". The "nr2" has to be one digit higher than "nr1". See bellow.
#include <Servo.h>
Servo myservo1;
Servo myservo2;
int blikk1[] = {100, 10, 120, 10};
int nr1 = 0;
int nr2 = 0;
int stad1 = 0;
int blikk2 =0;
 for(int i=0; i<4; i=i+1){
nr1 = blikk1[i];
nr2 = blikk2[i]++1; //this is my problem. I want the "nr2" to be one digit higher than the "nr1". I guess you can see how Im trying to do this.
Any sugestion would be appreciated.
Best
Ingirafn
nr1 = nr2 + 1;
EDIT: I mixed them up, see the post below... Embarrassing!
nr1 = nr2 + 1;
If that doesn't work, you could try:
nr2 = nr1 + 1;
nr2 = blikk [color=red]2[/color][i] [color=red]++[/color] 1;
Try:
nr2 = blikk1[i]+1 // for i = 0 this gives nr2=101
or
nr2 = blikk1[i+1] // for i = 0 this gives nr2=10
depending of what you want.
-Fletcher
:slight_smile:
Yes, so simple. Thanks.
:slight_smile:
