So im trying to build a midi controller,and i ran into this problem.
sometimes when my potentiometer sits just right it will flicker between two values.
I have tried to smoothen the readings by thaking the average of 10 readings but it was with no luck.
Then i tought "if i could code the arduino to only output serial when the potentiometer has been turned more than for example 4 values"
But i am not the best a coding yet so i sort you you forum to help...
right now i am using this code for one pot.
const int numReadings = 10;
int val = 0;
int lastVal = 0;
int readings[numReadings];
int readIndex = 0;
int total = 0;
int average = 0;
int Pot = A0;
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
total = total - readings[readIndex];
readings[readIndex] = analogRead(Pot)/8;
total = total + readings[readIndex];
readIndex = readIndex + 1;
delay(5);
// End of array
if (readIndex >= numReadings){
readIndex = 0;
average = total / numReadings;
val = average;
if (val !=lastVal)
MIDImessage(176,123,val);}
lastVal = val;
void MIDImessage(byte command, byte data1, byte data2)
Serial.write(command);
Serial.write(data1);
Serial.write(data2);
any other suggestions for a way to solve this will also be greatly appreciated.
Steamed_muffin
