Smoothing analog readings
I know there are already million of similar question and 10 million of answers. I have also tried some libraries and came up with decision for the sake of customization to work on own method for filtering. I have different kind of analog inputs and one of them is voltage measurement for example. Currently it is constantly jumping from 3.1 to 3.2. I would like to apply some kind of filter to it. SO I have came up with this method. However for some reason it does not do any filtering. What might be the reason?
 void readAnalogInputs()
  voltageValue = smooth(A2);
int smooth(int sensor){
  int i;
  int value = 0;
  int numReadings = 10;
  for (i = 0; i < numReadings; i++){
    // Read sensor data.
    value = value + analogRead(sensor);
    // 1ms pause adds more stability between reads.
    delay(1);
  // Take an average of all the readings.
  value = value / numReadings;
  return value;
I have also tried for example
#include <ResponsiveAnalogRead.h>
but it rounds to absolute number that is 3, I would like to receive more precise values 3.1 or 3.2...
That's the average value, I guess, since integers don't have anything to the right of the decimal point. And for the same reason, I'd say that's "smoothed"... :wink: Maybe the raw numbers are jumping between 3 & 4, or "worse".
And if you're reading about 3 on the 10-bit ADC (0-1023 range) you're not using much of its resolution and that might be a problem.
The ADC is integer, but for example if you convert that to voltage you can use a type-float in your calculation and you could get a meaningful result like 3.2V.
P.S.
I don't know what that library is doing but by-default integers are truncated, not properly rounded (3.99 becomes 3).
Instead of using volts, use millivolts.
consider
// running average (leaky integration)
float  avg;
const float K = 0.125;
void
loop ()
    int samp = analogRead (A0);
    if (0 != avg)
        avg += (samp - avg) * K;
        avg = samp;
    Serial.println (avg, 0.01);
    delay (250);
void
setup ()
    Serial.begin (9600);
Beyond what @DVDdoug said regarding precision, I would recommend a running average to smooth the analogs. Here is how I did it:
int smoothAnalog(int reading)
  const int numSamples = 10;
  static int samples[numSamples];
  static int sampleIndex = 0;
  static int sampleSum = 0;
  // Analogs are a 10-bit value (0-1023), therefore we could
  // average up to 32 values with a signed int.
  // NOTE: It will take 10 measurements to fill the sample
  // array and return a true smoothed value.  This is not a
  // problem for this application and not worth compensating for.
  // Update sum
  sampleSum -= samples[sampleIndex];
  samples[sampleIndex] = reading;
  sampleSum += samples[sampleIndex++];
  sampleIndex = sampleIndex % numSamples;
  // Return average of last numSamples measurements
  return sampleSum/numSamples;
"sample array" ?
My first version used an array and I then decided it was not needed. "Tsk tsk" on me for not updating the comment. BAD programmer! :open_mouth:
It probably was.
You are correct...or accumulate the sum until 10 samples have been added.
...and now you've changed the post, and made nonsense of both our comments.
Yes I did.
