I'm new to Arduino and trying to smooth some analog accelerometer data but receive only strange data in Processing. Any suggestions?
#define NUMREADINGS 10
int xVal, yVal, zVal = 0;
int readings[NUMREADINGS]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
//analog pins from accelerometer
int xPin = 0;
int yPin = 1;
int zPin = 2;
byte inByte;
establishContact();
for (int i = 0; i < NUMREADINGS; i++)
readings = 0; // initialize all the readings to 0 } void loop() {
// if we get a valid byte, read analog ins:*
if (Serial.available() > 0) {*
// get incoming byte:*
inByte = Serial.read();*
xVal = analogRead(xPin);*
yVal = analogRead(yPin);*
zVal = analogRead(zPin);*
Serial.print(xVal, BYTE);*
Serial.print(yVal, BYTE);*
Serial.print(zVal, BYTE);*
total -= readings[index]; // subtract the last reading*
readings[index] = analogRead(xPin); // read from the sensor*
readings[index] = analogRead(yPin);*
readings[index] = analogRead(zPin);*
total += readings[index]; // add the reading to the total*
index = (index + 1); // advance to the next index*
if (index >= NUMREADINGS) // if we're at the end of the array...*
index = 0; // ...wrap around to the beginning*
average = total / NUMREADINGS; // calculate the average*
Serial.println(average); // send it to the computer (as ASCII digits) *
I'm not sure what you are trying to do exactly, but there are a couple of things around this part of the code:
Why do you read the analog pins, send the data then read the pins again?
You seem to be adding all the x, y and z reading together into the reading[] array. Should you be using 3 different arrays? (or a 2 dimensional array).
Yes, it's a little strange. You're writing the ADC values to the same array location, so only the last one is stored. Definitely fix this with separate arrays and averaging variables, or two-dimensional arrays.
Doing a round-robin sampling approach like this works quite well, I've done it before in situations I wanted some sample averaging, but faster response to changes in input.
Couple other things to check. This approach requires either an ADC input signal centered near VCC/2, or signed variable types, since you will run into situations where the new value is larger than the current total. You've got signed variables, but does the Serial.println correctly print a negative integer? Can't say I've tried it, so I don't know.
More: you're trying to send ADC readings as BYTE types. Right in the Serial.println portion of the manual, it shows you have to divide by 4 since an ADC reading can exceed the value of a BYTE. Also, instead of doing another reading to assign values to your array, you could use the xVal etc that you just read.
