Hello! So I have been working on a system that controllers 110v blacklights through touch, yes I know there is a lot of info about these 110v controllers out there and it has gotten me far but I am still after tireless effort unable to get this jitter out of my system. Most recently I am using Paul Badgers configuration and code as explained in his library (Arduino Playground - CapacitiveSensor)
I have six sensors (using wire and tin foil) and a 6-channel 5V relay board controlling my blacklights, I am using a 10MOhm for each sensor.
What is happening is my numbers within Serial Monitor stay at around 300-400 but then unexpectedly spike up to 15000 or more! I have my threshold set to around this and then it triggers my light. I am using this system as an interactive performance running though MaxforLive to trigger sample in Ableton so jitter will seriously mess up the performance if a sample goes of when its not suppose to.
After alot of reading I read it could have something to do with the grounding so I put both the laptop charger and the Mains on the same ground, still happens. Happens more frequently when I am touching the computer also.
How might I fix this? I am thinking smoothing out the data might work since the spikes are so intermittent.
And/rr fixing the possible ground issue but I'm not sure what else to do about that, I have tried many methods.
Any help would be greatly appreciated!!
Thanks,
Chelsea
#include <CapacitiveSensor.h>
* CapitiveSense Library Demo Sketch
* Paul Badger 2008
* Uses a high value resistor e.g. 10 megohm between send pin and receive pin
* Resistor effects sensitivity, experiment with values, 50 kilohm - 50 megohm. Larger resistor values yield larger sensor values.
* Receive pin is the sensor pin - try different amounts of foil/metal on this pin
* Best results are obtained if sensor foil and wire is covered with an insulator such as paper or plastic sheet
//SENSORS
//ONLY TESTING WITH FIRST SENSOR CURRENTLY
CapacitiveSensor cs_4_2 = CapacitiveSensor(4,2); // 10 megohm resistor between pins 4 & 2, pin 2 is sensor pin, add wire, foil
//CapacitiveSensor cs_4_7 = CapacitiveSensor(4,7);
//CapacitiveSensor cs_4_8 = CapacitiveSensor(4,8);
//CapacitiveSensor cs_4_12 = CapacitiveSensor(4,12);
//CapacitiveSensor cs_4_13 = CapacitiveSensor(4,13);
//CapacitiveSensor cs_4_1 = CapacitiveSensor(4,1);
unsigned long csSum;
//6-channel relay board
const int relayPin1 = 3;
//const int relayPin2 = 5;
//const int relayPin3 = 6;
//const int relayPin4 = 9;
//const int relayPin5 = 10;
//const int relayPin6 = 11;
//pin setup for relay board
pinMode(relayPin1, OUTPUT);
//pinMode(relayPin2, OUTPUT);
//pinMode(relayPin3, OUTPUT);
//pinMode(relayPin4, OUTPUT);
//pinMode(relayPin5, OUTPUT);
//pinMode(relayPin6, OUTPUT);
// cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
// initialize all the readings to 0:
CSread();
void CSread() {
long cs = cs_4_2.capacitiveSensor(30); //a: Sensor resolution is set to 80
if (cs > 100) { //b: Arbitrary number
csSum += cs;
Serial.println(cs);
if (csSum >= 10000) //c: This value is the threshold, a High value means it takes longer to trigger
Serial.print("Trigger: ");
Serial.println(csSum);
digitalWrite(relayPin1, LOW); //Turn on relay 1 if sensor 1 is above threshold
if (csSum > 0 ) { csSum = 0; } //Reset
cs_4_2.reset_CS_AutoCal(); //Stops readings
csSum = 0; //Timeout caused by bad readings
digitalWrite(relayPin1, HIGH);
Serial.println(cs); // print sensor output 1
//Serial.print("\t");
//Serial.println(total2); // print sensor output 2
//Serial.println(total3); // print sensor output 3
delay(250);
PaulTest_blacklights.ino (2.55 KB)
