Hardware
XeThru X2M200 Respiration Sensor
Arduino Zero
Servo Motor
I am currently working on a project that allows me to translate my respiration rate to control a servo. The servo will eventually be integrated into a larger project that controls air flow within an inflatable object, allowing anyone to make the object breath with them. I have run into a problem and am wondering if anyone could assist me in thinking through how to smooth the data I am receiving so that the servo responds as accurately as possible(real time is the goal) to my breathing. I have been able to get the servo to rotate according to whether I am inhaling or exhaling, now I want it to basically track this so that the + and - rotation is incremental based on the data the Arduino is receiving from the board. Long slow breaths would produce different results than short breaths and I am trying to have the servo respond in real time to these variations. I have mapped the range but I need to now smooth the data so that the response is much less erratic. I need to control both speed and degree of rotation to correspond to the breathing rate. I have messed around with the smoothing example that is in the 03 analog sketch and tried to substitute variables:
//analog sensor location
int inputPin =A0;
becomes
// equals data.movement reading from the XeThru
float val;
and then change the call later in the sketch:
// read from the sensor:
readings[readIndex] = analogRead(inputPin);
to
// read from the data.movement variable:
readings[readIndex] = val;
When I do this it compiles and loads but the servo stops responding to movement and no longer detects inhalation
Here is the smoothing sketch for reference:
// initialize serial communication with computer:
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
// subtract the last reading:
total = total - readings[readIndex];
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
Serial.println(average);
delay(1); // delay in between reads for stability
This is the most current servo sketch without an adapted smoothing sketch. Additional coding is to provide the ability to visually understand what state the sensor and servo are in.
// Servo - Version: Latest
// Written by Øyvind Nydal Dahl
// www.build-electronic-circuits.com
// May 2017
//modified by Michael Casselli
//July 2017
#include <XeThruRadar.h>
#include <Servo.h>
// create servo object to control a servo
Servo myservo;
XeThruRadar radar;
// variable to read the value data.movement
float val;
// Serial port for debugging (Change to match the serial port on your Arduino)
#define SerialDebug SerialUSB
//LED pins
const int red_pin = 8;
const int green_pin = 10;
const int blue_pin = 12;
pinMode(red_pin, OUTPUT);
pinMode(green_pin, OUTPUT);
pinMode(blue_pin, OUTPUT);
// attaches the servo on pin 6 to the servo object
myservo.attach(6);
//Set LED to pink(?) while initializing radar
setColor(255, 0, 255, 1.0);
// Setup debug port in library (for developers)
// Note: Do not use without making sure the same port is NOT used in this sketch
//radar.enableDebug();
// Setup debug port for this sketch
SerialDebug.begin(115200);
// I use a delay so that I have 5 seconds to connect the radar after programming
delay(5000);
// Setup radar
radar.init();
// Tell the radar to load the respiration app
radar.load_respiration_app();
// Set detection zone (0.5 - 1.2 gives radar frame 0.3 - 2.3)
radar.setDetectionZone(0.5, 1.2);
// Set low sensitivity.
radar.setSensitivity(3);
// Start the app (the radar will start sending a constant stream of measurements)
radar.execute_app();
// Get respiration data
RespirationData data = radar.get_respiration_data();
if (data.valid_data == true)
// Set brightness of LED if in breathing state
if (data.state_code == radar._xts_val_resp_state_breathing) {
//Movement is usually between -1 and 1, so move it to 0 to 1 instead:
float brightness = data.movement + 1.0;
brightness += 1.0;
brightness = brightness / 5.0;
// Set brightness of the blue LED
setColor(0, 0, 255, brightness);
// reads the value of data.movement (value between 0 and 1023)
val = data.movement;
// scale it to use it with the servo (value between 0 and 180)
val = map(val, -5.5, 5.5 , 0, 180);
// sets the servo position according to the scaled value
myservo.write(val);
// waits for the servo to get there
SerialDebug.println(val);
//delay(15);
SerialDebug.println(data.movement);
else if (data.state_code == radar._xts_val_resp_state_initializing) {
setColor(255, 0, 255, 1.0); // Set color to pink
SerialDebug.println("State: Initializing");
else if (data.state_code == radar._xts_val_resp_state_movement) {
setColor(255, 255, 0, 1.0); // Set color to yellow
SerialDebug.println("Detects motion, but can not identify breath");
else if (data.state_code == radar._xts_val_resp_state_movement_tracking) {
setColor(0, 255, 0, 1.0); // Set color to green
SerialDebug.println("Detects motion, possible breathing");
else if (data.state_code == radar._xts_val_resp_state_no_movement) {
setColor(255, 0, 0, 1.0); // Set color to red
SerialDebug.println("No movement detected");
else {
setColor(255, 255, 255, 1.0); // Set color to white
//SerialDebug.println("Unknown state");
else {
setColor(0, 255, 255, 1.0); // Set color to cyan
SerialDebug.println("Valid respiration data NOT received!");
void setColor(int red, int green, int blue, float brightness)
//Make sure brightness is between 0 and 1:
if (brightness > 1.0)
brightness = 1.0;
else if (brightness < 0.0)
brightness = 0.0;
//Set the brightness of each color
analogWrite(red_pin, 255 - red * brightness);
analogWrite(green_pin, 255 - green * brightness);
analogWrite(blue_pin, 255 - blue * brightness);
void blink_red() {
while (1) {
setColor(0, 0, 0, 0.0);
void blink_green() {
while (1) {
void blink_blue() {
while (1) {
setColor(0, 0, 255, 1.0);
Many Thanks to Oyvind Nydal Dahl for his work on this with me. I am pretty much a noob with this level at this level of programming but am trying to learn and willing to experiment. Any suggestions, tips, recommendations about how I can achieve a real time response that controls the servo will be much appreciated.
Thank you.
XeThruRadar.cpp (11.7 KB)
XeThruRadar.h (4.04 KB)
float_no_smoothing.ino (4.23 KB)
