Smoothing Irms
 // EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3
#include <LiquidCrystal.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
#include "EmonLib.h"                   // Include Emon Library
EnergyMonitor emon1;                   // Create an instance
const int numReadings = 10;
int readings[numReadings];      // the readings from the analog input
int readIndex = 0;              // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
int Irms;
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
  lcd.begin(16, 2);
  emon1.current(PA7, 2.8);             // Current: input pin, calibration.
  double Irms = emon1.calcIrms(1480);  // Calculate Irms only
  // subtract the last reading:
  total = total - readings[readIndex];
  // read from the sensor:
  // readings[readIndex] = analogRead(PA7);
  readings[readIndex] = Irms;
  // add the reading to the total:
  total = total + readings[readIndex];
  // advance to the next position in the array:
  readIndex = readIndex + 1;
  // if we're at the end of the array...
  if (readIndex >= numReadings) {
    // ...wrap around to the beginning:
    readIndex = 0;
 average = total / numReadings;
  Serial.println(average);
  delay(1);
  lcd.setCursor(0, 1);
  lcd.print("U=");
  lcd.print(Irms);
  lcd.setCursor(0, 0);
  lcd.print("A=");
  lcd.print(average);
Hi
The program above it is a AC meter, I need to smooth the readings to get stable numbers on LCD, to do that I need to average Irms , when I using traditional arduino smoothing the reading non LCD
lcd.print(average);is only integer - 0,1,2 ,3.
How to fix it?
int average = 0;
lcd.print(average);
No surprise there.
Start by declaring average and total as floats
I changed to;
float total = 0;                  // the running total
float average = 0;                // the average
Results are the same.
Let's see your new code
//int total = 0;                  // the running total
//int average = 0;                // the average
int Irms;
  lcd.begin(16, 2);
    readIndex = 0;
  delay(1);
  lcd.print("U=");
  lcd.print(Irms);
  lcd.print("A=");
  lcd.print(average);
Your readings are all 'double' so your array to store them should probably be 'double', not 'int'.
//double readings[numReadings];      // not good - compiling error
//double readIndex = 0;              //not good - compiling error
 double total ;
 double average = 0;                // the average
//float total ;                  // the running total
//float average ;                // the average
int Irms;
  lcd.begin(16, 2);
    readIndex = 0;
  delay(1);
  lcd.print("U=");
  lcd.print(Irms);
  lcd.print("A=");
  lcd.print(average);
No changes in results
readings is an array of ints but Irms is a double
This line is commented out
What error did you get ?
UKHeliBob:
exit status 1
conflicting declaration 'double readings [10]'
exit status 1
How many times did you declare readings in the code ?
Did you have this as well ?
UKHeliBob:
The reading for averaging is not from analog input pin but Irms.
The signal is on analog input pin - "EmonLib.h"- calculate the amplitude = Irms. I am trying to average Irms not analog input, when I do that (smoothing analog pin ) the average is 2.5V which is the bias on the pin.
This is last code and error
//int readings[numReadings];      // the readings from the analog input
//int readIndex = 0;              // the index of the current reading
 double total ;
int Irms;
  lcd.begin(16, 2);
    readIndex = 0;
  delay(1);
  lcd.print("U=");
  lcd.print(Irms);
  lcd.print("A=");
  lcd.print(average);
AC_smoothing:50:37: error: invalid types 'double [10][double]' for array subscript
AC_smoothing:53:21: error: invalid types 'double [10][double]' for array subscript
AC_smoothing:56:35: error: invalid types 'double [10][double]' for array subscript
exit status 1
The index to an array must be an integer as there will always be 0, 1, 2, 3 etc element in the array. There can never be, for instance, 1.5 elements in the array
Declare readIndex as an integer
So what solution can be, averaging 10 reading of the data = Irms ?
Applying smoothing function to DC voltmeter it is working Ok, I have average in not integer numbers.
We can’t see your code
This change was a mistake:
TheMemberFormerlyKnownAsAWOL:
We can't see your code
Please look post #1, I have to start from beginning.
But you’ve changed that code to make the array and total to be both of type “double”, right?
So post that code.
 double total ;
int Irms;
  lcd.begin(16, 2);
    readIndex = 0;
  delay(1);
  lcd.print("U=");
  lcd.print(Irms);
  lcd.print("A=");
  lcd.print(average);
