I'm having a load of issues with what I though would be quite a simple little component of a larger project.
Pretty simple task - make a position controlled drum which can rotate infinitely in either direction to an angular position which is sent to the micro-controller. (Most likely with I2C eventually but im just going to use serial for now).
Im using an Uno, a standard little 6v DC hobby motor, an L298N, to measure the position im using an AMS-AS5048b magnetic position sensor.
The standard way to do this seems to be a stepper and a optical encoder but due to the small package size I'm going to need to fit this in to eventually I went for DC motors and the little hall effect sensor instead, and I'll replace the L298N with a TB6612FNG.
Here's some photos of the test rig I made. The orange drum has the magnet recessed in the end.
My issue is the PID is being extremely temperamental to tune. Most of the time it rocks consistently back and forth passed the set point at maximum speed. Here's a little video and the output graph.
I've managed to tune it to the point where it steadies out but as you can see in the graphs it's still very unstable during the deceleration. I'm also getting about 5 degrees of steady-state error from this when I do a 360 to -360 sweep.
So I'm a little baffled really. I'm not sure if it's an error with the PID, with the hardware, or with the Code.
Any help appreciated.
One other strange thing I noticed is uploading the exact same code using the default arduino IDE and using VS code platformio results in different level of stability, with the VScode version being much more unstable. Any ideas?
#include <Arduino.h>
#include <PID_v1.h>
#include <ams_as5048b.h> //https://github.com/sosandroid/AMS_AS5048B
//Constants required for position sensor
#define U_RAW 1
#define U_TRN 2
#define U_DEG 3
#define U_RAD 4
#define U_GRAD 5
#define U_MOA 6
#define U_SOA 7
#define U_MILNATO 8
#define U_MILSE 9
#define U_MILRU 10
//Postion Sensor Device
AMS_AS5048B sensor1(0x40);
//Motor Pins and Constants
#define MO1 9 //Motor Enable(Speed) Pin
#define CW1 10 //Clockwise Pin
#define ACW1 11 //Anti-clockwise Pin
#define MAX_PWM 255 //Motor Max PWM value
#define MIN_PWM 140 //Motor Min PWM value
//Control Variables
double Input = 0, Setpoint = 0, Output = 0; //For PID controller
int motor_speed, rots = 0; //For Calculating True Position
double sens_ang, prev_ang = 0;
#define window 30
#define MAX_OUTPUT 100
#define MIN_ERROR 2
bool new_data = false; //New data receive flag
//Controller Constants
double Kp = 5, Ki = 1.4, Kd = 0.0125;
//Set up PID
PID pid1(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
//Print for Monitor or Plotter
bool graph = false;
/////////SUBROUTINES//////////
void get_true_position()
sens_ang = sensor1.angleR(U_DEG, true); //Get Position from 0-360 from Sensor
if (prev_ang > (360 - window) && prev_ang <= 360)
if (sens_ang >= 0 && sens_ang < window)
rots++; //If has moved clockwise add 1 to rotation
if (prev_ang >= 0 && prev_ang < window)
if (sens_ang <= 360 && sens_ang > (360 - window))
rots--; //If moved acw take one away.
prev_ang = sens_ang;
Input = sens_ang + (360 * rots); //Calculate true position
void clockwise()
digitalWrite(CW1, HIGH);
digitalWrite(ACW1, LOW);
void anticlockwise()
digitalWrite(CW1, LOW);
digitalWrite(ACW1, HIGH);
void motor_off()
//Serial For Debug
Serial.setTimeout(500); //Lower Timeout to speed up loop when new data received.
//Motor Pins
pinMode(MO1, OUTPUT);
pinMode(CW1, OUTPUT);
pinMode(ACW1, OUTPUT);
//Start sensor and set current position as zero.
sensor1.begin();
sensor1.setZeroReg();
sensor1.setClockWise(true);
//Set up PID
pid1.SetMode(AUTOMATIC);
pid1.SetSampleTime(1);
pid1.SetOutputLimits(-MAX_OUTPUT, MAX_OUTPUT);
//Change base PWM fq. to reduce motor noise
TCCR1B = TCCR1B & 0b11111000 | 1;
//Get new Setpoint from Serial if new data is available.
new_data = Serial.available();
if (new_data == true)
Setpoint = Serial.parseInt();
//reset flag
new_data = false;
//Get True Position
get_true_position();
//Calculate PID
pid1.Compute();
//Output is value from -100 to 100 which must be converted to PWM to send motor between -255 and 255.
//Positive is Clockwise. However, motor will not turn if output is below MIN_PWM.
//Additionally, Only let motor turn if output is above a threshold to prevent shuddering
if (Output > MIN_ERROR)
clockwise();
motor_speed = map(abs(Output), 0, MAX_OUTPUT, MIN_PWM, MAX_PWM);
else if (Output < -MIN_ERROR)
anticlockwise();
motor_speed = 0;
motor_off();
motor_speed = round(motor_speed);
analogWrite(MO1, motor_speed);
//Print Info to Serial
if (graph == true)
Serial.print("Target_Angle: ");
Serial.print("Measured_Angle: ");
Serial.println(Setpoint);
Serial.print("\t");
Serial.println(Input);
Serial.print("\t");
Serial.print("Time:");
Serial.print("\t");
Serial.print(millis());
Serial.print("\t");
Serial.print("Target Angle:");
Serial.print("\t");
Serial.print(Setpoint);
Serial.print("\t");
Serial.print("Measured Angle:");
Serial.print("\t");
Serial.print(Input);
Serial.print("\t");
Serial.print("PID Output:");
Serial.print("\t");
Serial.print(Output);
Serial.print("\t");
Serial.print("Motor Speed:");
Serial.print("\t");
Serial.println(motor_speed);
