smoothing ultrasonic readings
I’m building a sensor to ultimately transmit midi CC messages. The code below works, but the values are erratic - I want to provide smoothed readings between 70 and 0, so have divided the returned value to get the readings within the range I need, to correspond to the maximum distance I want it to react to. Any suggestions? I’ve tried various smoothing codes without success.
// testing ultrasonic detector - display values
const int trigPin = 3;
const int echoPin = 2;
long duration;
int distance;
int led = 9;           // the PWM pin the LED is attached to
int brightness = 0;    // how bright the LED is
pinMode(led, OUTPUT);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT);  // Sets the echoPin as an Input
Serial.begin(9600);       // Starts the serial communication
digitalWrite(trigPin, LOW);     // Clears the trigPin
delayMicroseconds(2);           // gap between readings
digitalWrite(trigPin, HIGH);    // Sets the trigPin on HIGH state for 10 micro seconds
delayMicroseconds(5);           // gap between readings
analogWrite(led, 255);     // set the brightness of pin 9:
duration = pulseIn(echoPin, HIGH);    // Reads the echoPin, returns the sound wave travel time in microseconds
distance= duration*0.05;  // Calculating the distance
if (distance <70 && distance >7)    // ignore outside suitable range
  analogWrite(led, (distance*4));     // set the brightness of pin 9:
  Serial.print("Distance: ");
  Serial.println(distance);
Hi, See the NewPing library which has this capability:
Start HERE
See Tim Eckel's info and library HERE
thanks, I'll check this out. I've been a bit wary of libraries, since I'm trying to learn and don't understand how they work internally, but I guess I need to just accept that they work!
I’ve been a bit wary of libraries,
Hey, I like to make my own pizza, but sometimes I just buy a finished one from someone else. Libraries are better: they are free and you can make as many copies as you want…
See THIS about Libraries
Sadly, that is not a good assumption.
Most have poor documentation, do not have good error checking and many simply don't work under a number of different circumstances, for example if you use two libraries that use the same resource, like a timer.
Always test before you trust, and post on the forum if you run into difficulties with a particular library, as forum members are aware of many of the problems.
