sms based led turn off not working
I tried the following program in Arduino to turn off an LED at pin 12. by sending an sms "offa". I used a gprs shield.
I got the following output in serial monitor. and the LED didn't turned OFF.
Can you please say what may be the problem?
code and output are attached
#include <SoftwareSerial.h>
// EN: String buffer for the GPRS shield message
String msg = String("");
// EN: Set to 1 when the next GPRS shield message will contains the SMS message
int SmsContentFlag = 0;
//control pins of relay.
int a=12;
// EN: Code PIN of the SIM card (if applied)
//String SIM_PIN_CODE = String( "XXXX" );
  Serial.begin(19200);                 // the GPRS baud rate
  // Initialize  PINs
  pinMode( 12, OUTPUT );
  digitalWrite( 12, HIGH );
 Serial.println( "AT+CMGF=1" );
 delay(200);
    char SerialInByte;
    if(Serial.available())
        SerialInByte = (unsigned char)Serial.read();
       delay(5);
        // EN: Program also listen to the GPRS shield message.
       // EN: If the message ends with <CR> then process the message
        if( SerialInByte == 13 ){
          // EN: Store the char into the message buffer
          ProcessGprsMsg();
         if( SerialInByte == 10 ){
            // EN: Skip Line feed
         else {
           // EN: store the current character in the message string buffer
           msg += String(SerialInByte);
// EN: Make action based on the content of the SMS.
//     Notice than SMS content is the result of the processing of several GPRS shield messages.
void ProcessSms( String sms ){
  if( sms.indexOf("offa") >= 0 ){
    digitalWrite( a, LOW );
// EN: Request Text Mode for SMS messaging
void GprsTextModeSMS(){
void GprsReadSmsStore( String SmsStorePos ){
  Serial.print( "AT+CMGR=" );
  Serial.println( SmsStorePos );
// EN: Clear the GPRS shield message buffer
void ClearGprsMsg(){
  msg = "";
// EN: interpret the GPRS shield message and act appropiately
void ProcessGprsMsg() {
  if( msg.indexOf( "Call Ready" ) >= 0 ){
     Serial.println( "*** GPRS Shield registered on Mobile Network ***" );
     GprsTextModeSMS();
  // EN: unsolicited message received when getting a SMS message
  if( msg.indexOf( "+CMTI" ) >= 0 ){
    Serial.println( "*** SMS Received ***" );
     // EN: Look for the coma in the full message (+CMTI: "SM",6)
     //     In the sample, the SMS is stored at position 6
     int iPos = msg.indexOf( "," );
     String SmsStorePos = msg.substring( iPos+1 );
    Serial.print( "SMS stored at " );
     // EN: Ask to read the SMS store
     GprsReadSmsStore( SmsStorePos );
  // EN: SMS store readed through UART (result of GprsReadSmsStore request)
  if( msg.indexOf( "+CMGR:" ) >= 0 ){
    // EN: Next message will contains the BODY of SMS
    SmsContentFlag = 1;
    // EN: Following lines are essentiel to not clear the flag!
    ClearGprsMsg();
    return;
  // EN: +CMGR message just before indicate that the following GRPS Shield message
  //     (this message) will contains the SMS body
  if( SmsContentFlag == 1 ){
    Serial.println( "*** SMS MESSAGE CONTENT ***" );
    Serial.println( msg );
    Serial.println( "*** END OF SMS MESSAGE ***" );
    ProcessSms( msg );
  ClearGprsMsg();
  // EN: Always clear the flag
  SmsContentFlag = 0;
AT+CMGF=1
SMS stored at 7
AT+CMGR=7
