SMS difficulties
I've been trying this one out for a while now and I got a problem with the sms code. It doesn't read incoming sms. I just want to continuously wait for incoming sms so that if the text is correct, the led will light up, otherwise it won't. I can't think what is wrong or missing..
char inchar;  //Will hold the incoming character from the Serial Port.
int led1 = 9;
int led2 = 10;
int led3 = 11;
int led4 = 12;
  // prepare the digital output pins
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  digitalWrite(led1, LOW);
  digitalWrite(led2, LOW);
  digitalWrite(led3, LOW);
  digitalWrite(led4, LOW);
  //Initialize GSM module serial port for communication.
  Serial.begin(9600); //  for GSM module communication
  delay(1000); // give time for GSM module to register on network etc.
  Serial.println("AT+CMGF=1"); // set SMS mode to text
  delay(200);
  Serial.println("AT+CMGL=\"REC UNREAD\"");
  delay(200);
  Serial.println("AT+CNMI=3,3,0,0"); // set module to send SMS data to serial out upon receipt
  delay(200);
  //If a character comes in from the cellular module...
  if(Serial.available() >0)
    inchar=Serial.read();
    if (inchar=='#')
      delay(10);
      if (inchar=='a')
        delay(10);
        if (inchar=='0')
        else if (inchar=='1')
          digitalWrite(led1, HIGH);
        delay(10);
        if (inchar=='b')
          if (inchar=='0')
            digitalWrite(led2, HIGH);
          delay(10);
          if (inchar=='c')
            if (inchar=='0')
              digitalWrite(led3, HIGH);
            delay(10);
            if (inchar=='d')
              delay(10);
              if (inchar=='0')
                digitalWrite(led4, HIGH);
              delay(10);
          Serial.println("AT+CMGD=1,0");
Moderator: I split this post off - it seems to have nothing to do with the original topic it was posted under.
AWOL
It would be a lot easier if you moved the sms device to some other pins, and used NewSoftSerial to talk to it. Then, you could use the hardware serial port to send data to a PC, for debugging purposes. Otherwise, you haven't a clue how the sms device is responding to the commands you issue.
Oops, sorry If I post it to the same thread. I forgot it was off topic. :slight_smile:
@PaulS: I'll try it.Thanks!
I tried this but still doesn't do anything.. I don't even get anything from the serial monitor. I reinstalled the newsoftserial library and restarted the IDE but no luck.
 #include <NewSoftSerial.h>  //Include the NewSoftSerial library to send serial commands to the cellular module.
NewSoftSerial cell(2,3);    //Create a 'fake' serial port. Pin 2 is the Rx pin, pin 3 is the Tx pin.
int led1 = 9;
int led2 = 10;
int led3 = 11;
int led4 = 12;
{    // prepare the digital output pins
  digitalWrite(led4, LOW);    //Initialize GSM module serial port for communication.
  cell.begin(9600);
  cell.println("AT+CMGF=1"); // set SMS mode to text
  delay(200);
  cell.println("AT+CNMI=3,3,0,0"); // set module to send SMS data to serial out upon receipt
  delay(200);
  if(cell.available() >0)
    inchar=cell.read();
    if (inchar=='#') // OK - the start of our command
      delay(10);
      inchar=cell.read();
      if (inchar=='a')
        delay(10);
        inchar=cell.read();
        if (inchar=='0')
        delay(10);
        inchar=cell.read();
        if (inchar=='b')
          inchar=cell.read();
          if (inchar=='0')
          delay(10);
          inchar=cell.read();
          if (inchar=='c')
            inchar=cell.read();
            if (inchar=='0')
            delay(10);
            inchar=cell.read();
            if (inchar=='d')
              delay(10);
              inchar=cell.read();
              if (inchar=='0')
              delay(10);
          cell.println("AT+CMGD=1,0");
The reason for using NewSoftSerial is so that it frees up the Serial port for debugging. That means that you are supposed to add some debugging statements.
Can you help me with that?
By the way, I've managed to get the code from the first post working by moving the AT commands from the loop() to the setup(). I am now able to receive and read the sms but only works after resetting the arduino. So everytime I received sms, I have to reset the board in order to read it and to do what it has to do.
int led1 = 9;
int led2 = 10;
int led3 = 11;
int led4 = 12;
  delay(200);
  delay(200);
  delay(2000);
    if (inchar=='#')
      delay(10);
      if (inchar=='a')
        delay(10);
        if (inchar=='0')
        delay(10);
        if (inchar=='b')
          if (inchar=='0')
          delay(10);
          if (inchar=='c')
            if (inchar=='0')
            delay(10);
            if (inchar=='d')
              delay(10);
              if (inchar=='0')
              delay(10);
It might have something to do with the AT+CNMI command. Try adding another zero to the end, it should have 5 arguments.
Still the same.I want the gsm to continuously wait and read new sms but putting these AT commands inside the loop() doesn't seem to receive and read the new sms at all but the commands are in the setup() it will work but needs to reset the board after receiving sms so that it will execute what's inside the loop(). PLEASE HELP :frowning:
  delay(200);
  delay(200);
Which GSM are you using?
Have you connected the GSM module to something like Hyperterminal to make sure the AT commands are doing what you expect them to do?
I'm using SIM900D.When using hyperterminal, both receiving and sending sms is okay . Only in arduino not working.Don't know why. Do you think there's something missing in the code? Putting the AT commands inside the loop() should work out fine right since it works when in setup()?? Don't know what to do now..
If the SMS is automatically displayed to the terminal what is the purpose of the CMGL function? I can probably test it later but if the message goes straight to the terminal and then you issue a AT+CMGL="REC UNREAD" it probably won't show anything because the SMS should now be classified as READ.
I'm assuming you're checking the body of the SMS for some string you've sent it, but can you tell us exactly what is being received? In other words add some Serial prints for debugging.
I want the program to read only the new sms therefore only the unread sms which is currently received by the gsm module. And after the program reads it, it will delete it so that there will be no sms in the inbox.When I get this whole thing work, I am going to implement this on my project which is the electronic vault wherein you can open it via sms.:smiley:
I don't see why not. If you had an extra IO pin available you could just monitor the Ring Indicator pin on the GSM by setting an interrupt on the falling edge. When an SMS is received the pin goes low and then you could send a CMGR to read the message.
I don't have any extra io pin left. :frowning:
