SMS message to control 4 relays
hello,
I am looking for developer to create some code to operate 4 relays depending on the SMS message received. I have tried to use the code below with an Uno v3 and a sim900 from Maplin.
I can send AT commands to the sim900 and send and receive sms messages but the code below doesn't appear to do anything, although there are no errors when compiling or uploading.
#include <SoftwareSerial.h>
// EN: String buffer for the GPRS shield message
String msg = String("");
// EN: Set to 1 when the next GPRS shield message will contains the SMS message
int SmsContentFlag = 0;
//control pins of relay.
int relay_a=4;
int relay_b=5;
int relay_c=6;
int relay_d=7;
// EN: Code PIN of the SIM card (if applied)
//String SIM_PIN_CODE = String( "XXXX" );
  Serial.begin(19200);                 // the GPRS baud rate
  // Initialize  PINs
  pinMode( 4, OUTPUT );
  pinMode( 5, OUTPUT );
  pinMode( 6, OUTPUT );
  pinMode( 7, OUTPUT );
  digitalWrite( 4, LOW );
  digitalWrite( 5, LOW );
  digitalWrite( 6, LOW );
  digitalWrite( 7, LOW );
 Serial.println( "AT+CMGF=1" );
 delay(200);
    char SerialInByte;
    if(Serial.available())
        SerialInByte = (unsigned char)Serial.read();
       delay(5);
        // EN: Program also listen to the GPRS shield message.
       // EN: If the message ends with <CR> then process the message
        if( SerialInByte == 13 ){
          // EN: Store the char into the message buffer
          ProcessGprsMsg();
         if( SerialInByte == 10 ){
            // EN: Skip Line feed
         else {
           // EN: store the current character in the message string buffer
           msg += String(SerialInByte);
// EN: Make action based on the content of the SMS.
//     Notice than SMS content is the result of the processing of several GPRS shield messages.
void ProcessSms( String sms ){
  if( sms.indexOf("ona") >= 0 ){
    digitalWrite( relay_a, HIGH );
   if( sms.indexOf("onb") >= 0 ){
    digitalWrite(  relay_b, HIGH );
   if( sms.indexOf("onc") >= 0 ){
    digitalWrite(  relay_c, HIGH );
  if( sms.indexOf("ond") >= 0 ){
    digitalWrite(  relay_d, HIGH );
  if( sms.indexOf("offa") >= 0 ){
    digitalWrite(  relay_a, LOW );
  if( sms.indexOf("offb") >= 0 ){
    digitalWrite(  relay_b, LOW );
  if( sms.indexOf("offc") >= 0 ){
    digitalWrite(  relay_c, LOW );
  if( sms.indexOf("offd") >= 0 ){
    digitalWrite(  relay_d, LOW );
// EN: Request Text Mode for SMS messaging
void GprsTextModeSMS(){
void GprsReadSmsStore( String SmsStorePos ){
  Serial.print( "AT+CMGR=" );
  Serial.println( SmsStorePos );
// EN: Clear the GPRS shield message buffer
void ClearGprsMsg(){
  msg = "";
// EN: interpret the GPRS shield message and act appropiately
void ProcessGprsMsg() {
  if( msg.indexOf( "Call Ready" ) >= 0 ){
   //  Serial.println( "*** GPRS Shield registered on Mobile Network ***" );
     GprsTextModeSMS();
  // EN: unsolicited message received when getting a SMS message
  if( msg.indexOf( "+CMTI" ) >= 0 ){
   //  Serial.println( "*** SMS Received ***" );
     // EN: Look for the coma in the full message (+CMTI: "SM",6)
     //     In the sample, the SMS is stored at position 6
     int iPos = msg.indexOf( "," );
     String SmsStorePos = msg.substring( iPos+1 );
   //  Serial.print( "SMS stored at " );
  //   Serial.println( SmsStorePos );
     // EN: Ask to read the SMS store
     GprsReadSmsStore( SmsStorePos );
  // EN: SMS store readed through UART (result of GprsReadSmsStore request)
  if( msg.indexOf( "+CMGR:" ) >= 0 ){
    // EN: Next message will contains the BODY of SMS
    SmsContentFlag = 1;
    // EN: Following lines are essentiel to not clear the flag!
    ClearGprsMsg();
    return;
  // EN: +CMGR message just before indicate that the following GRPS Shield message
  //     (this message) will contains the SMS body
  if( SmsContentFlag == 1 ){
 //   Serial.println( "*** SMS MESSAGE CONTENT ***" );
 //   Serial.println( msg );
 //   Serial.println( "*** END OF SMS MESSAGE ***" );
    ProcessSms( msg );
  ClearGprsMsg();
  // EN: Always clear the flag
  SmsContentFlag = 0;
happy to pay for the code if people can contact me with prices.
thanks in advance
Dave
You need to get the sim900 off of the hardware serial pins, so you can use them for debugging.
    char SerialInByte;
Why do you use a type in the name when the type in the name is not the type of the variable? If you really feel the need to do that, why not call the variable serialInFloat? It would make as much, or as little, sense.
       delay(5);
Absolutely no need for that crap.
The += operator is overloaded to take a char. No need to piss away resources making a one character String.
I could me mistaken, but it does not appear that you ever actually do anything with msg.
Hi Paul,
thanks for the reply, it may be worth noting I did not create this code. I am not a coder I am an unfortunate network engineer tasked with find a method of power-cycling very remote kit via an SMS message should the satellite link to the internet fail. Currently we often face a 200-300 mile round trip just to cycle the power on an installation.
I am more than happy to pay for the code to be created for me.
thanks again
Dave
