a55830
December 9, 2015, 7:00pm
1
Hi again
iv got it to work but not realy.....
ill explain my build:
Uno and SensorShield
and a GSM board.
and some sensors and servos
when i send "Test"
it reply with the temp... from DHT11
but som how the "Test" gets lost or is broken somehow
Here is the code:
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "DHT.h"
#include "sms.h"
#include <Servo.h>
SMSGSM sms;
boolean started=false;
char smsbuffer[160];
char n[20];
char txt[160];
String d;
String textForSMS;
int numdata;
int resetPin = 8;
int ledPin1 = 13;
int fanPwr = 11;
int servPin1 = 9;
int servPin2 = 10;
int rpm = 0;
int pos1 = 90;
int pos2 = 90;
int fanPin = 0;
#define DHTPIN 12
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
Servo myservo1; // create servo object to control a servo
Servo myservo2; // a maximum of eight servo objects can be created
//Serial connection.
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(2400)) {
Serial.println("\nstatus=READY");
started=true;
} else Serial.println("\nstatus=IDLE");
if(started) {
//Enable this two lines if you want to send an SMS.
//if (sms.SendSMS("4040xxxx", "Arduino SMS booted up"))
//Serial.println("\nArduino SMS booted up");
pinMode(ledPin1,OUTPUT);
pinMode(servPin1,OUTPUT);
pinMode(servPin2,OUTPUT);
pinMode(resetPin,OUTPUT);
pinMode(fanPwr,OUTPUT);
// Servo Setup
myservo1.attach(servPin1); // attaches the servo on pin 9 to the servo object
myservo2.attach(servPin2);
myservo1.write(pos1);
myservo1.write(pos2);
delay(2000);
rpm = analogRead(fanPin);
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t))
Serial.println("Failed to read from DHT sensor!");
return;
if (t > 26)
analogWrite(fanPwr, 200);
analogWrite(fanPwr, 0);
Serial.print("Fugtighed : ");
Serial.print(h);
Serial.print("% ");
Serial.print("Temp : ");
Serial.print(t);
Serial.print("ºC ");
Serial.print("RPM : ");
Serial.print(rpm);
Serial.println("rpm");
// SMS Text
textForSMS = "Humidity : ";
textForSMS.concat(h);
textForSMS = textForSMS + "% Temp : ";
textForSMS.concat(t);
textForSMS = textForSMS + "ºC";
//SMS Respond
if(started) {
//Read if there are messages on SIM card and print them.
if(gsm.readSMS(smsbuffer, 160, n, 20)) {
d = smsbuffer;
Serial.print(n);
Serial.print(" Sendt this message : ");
Serial.println(d);
if (d == "Temp ")
textForSMS.toCharArray(txt, 160);
sms.SendSMS(n, txt);
Serial.println(d);
Serial.print("SMS Sendt to : ");
Serial.println(n);
else if (d == "Led on")
Serial.print(d);
Serial.println("LED ON");
analogWrite(ledPin1, 150);
else if (d == "Left")
servLeft;
Serial.print("Turning Left : ");
Serial.print(pos1);
else if (d == "Right")
Serial.println("Turning Right");
servRight;
else if (d == "Up")
Serial.println("Moving up");
servUp;
else if (d == "Down")
Serial.println("Moving down");
servDown;
else if (d == "ServoReset")
pos1 = 90;
pos2 = 90;
Serial.println("Servo Reset");
servReset;
Serial.println("Nothing to repport");
void servLeft()
for(pos1 = 30; pos1 < 190; pos1 += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo1.write(pos1); // tell servo to go to position in variable 'pos'
delay(5); // waits 15ms for the servo to reach the position
void servRight()
for(pos1 = 190; pos1>=30; pos1-=1) // goes from 180 degrees to 0 degrees
delay(5);
void servUp()
for(pos2 = 190; pos2>=30; pos2-=1) // goes from 180 degrees to 0 degrees
myservo2.write(pos2); // tell servo to go to position in variable 'pos'
delay(5);
void servDown()
delay(5);
void servReset()
delay(5);
system
December 9, 2015, 7:14pm
2
char n[20];
char txt[160];
Those buffers seem overly large to hold "Test".
String d;
String textForSMS;
You do not need to piss away resources using Strings.
Only struct and class bodies need a ; after the }. Functions and if/for/while statement bodies do not.
That SAME data is in smsbuffer. There is no need to wrap it in a String instance and then unwrap it into another array.
if (d == "Temp ")
Do you really send a space after "Temp"?
servLeft;
What is this supposed to do?
It most certainly does not.
Print the actual text message between delimiters:
Serial.print("smsbuffer: [");
Serial.print(smsbuffer);
Serial.println("]");
Does the text message contain a space, when you send Test?
Can you explain in more detail what goes wrong?
Nowhere in your code I can find where you send / receive the word 'Test'.
a55830
December 9, 2015, 9:13pm
4
well
reason for the big buffers is :
sms's can hold up to 160 char
n = number can be up to 20 numbers
ok Test should be Temp
and when o type on my phone it put a space after the word , why i dont know.
i know my code is messy... im new to this and im learning as i go.
a55830
December 9, 2015, 9:21pm
5
got this respond from SerialMonitor
ATT: +CMGL
RIC:
+CMGL: 1,"REC UNREAD","+454040xxxx","","15/12/09,22:19:15+04"
Temp
OK
ATT: OK
RIC:
OK
+454040xxxx Sendt this message : smsbuffer: [Temp]
Nothing to repport
Fugtighed : 39.00% Temp : 19.00ºC RPM : 249rpm
ATT: +CMGL
RIC:
OK
a55830
December 9, 2015, 9:42pm
6
this is the respond text and has nothing to doo with the smsbuffer
// SMS Text
this is making this sms tekst : Humidity : xx.xx% Temp : xx.xxºC
system
December 10, 2015, 9:50am
7
smsbuffer: [Temp]
I do NOT see a space after Temp.
a55830
December 10, 2015, 10:37am
8
well what i need help with is why it dont react when it get the right text... where it goes wrong i dont know
but i know that is in this part:
if(gsm.readSMS(smsbuffer, 160, n, 20)) { // checking for SMS if status is ready
Serial.print(n); // printing the number if there is a sms
Serial.print(" Sendt this message : ["); // Printing the message
Serial.print(smsbuffer); //
Serial.println("]"); //
if (smsbuffer == "Temp") // if there is a message with Temp
{ // send a message return to the Number
textForSMS.toCharArray(txt, 40); // converting a string to a char
sms.SendSMS(n, txt); // sending the sms
Serial.println(n);
else if (smsbuffer == "Led on")
else if (smsbuffer == "Left")
servLeft;
Serial.print(pos1);
else if (smsbuffer == "Right")
servRight;
else if (smsbuffer == "Up")
servUp;
else if (smsbuffer == "Down")
servDown;
else if (smsbuffer == "ServoReset")
pos1 = 90;
pos2 = 90;
servReset;
else Serial.println("Nothing to repport");
system
December 10, 2015, 11:08am
9
smsbuffer is a character array. The address of the array is not likely to be the same as the address of "Temp".
Use strcmp() to compare strings.
a55830
December 10, 2015, 12:56pm
11
ok i got it to work with this
if (strncmp(smsbuffer,"Temp", 4) == 0)
thx for your input it helped me a lot
a55830
December 10, 2015, 1:29pm
12
here is the code
#include "SIM900.h"
#include "DHT.h"
#include "sms.h"
#include <Servo.h>
SMSGSM sms;
char n[12];
char txt[40];
String textForSMS;
int numdata;
int resetPin = 8;
int ledPin1 = 13;
int fanPwr = 11;
int servPin1 = 9;
int servPin2 = 10;
int rpm = 0;
int pos1 = 90;
int pos2 = 90;
int fanPin = 0;
#define DHTPIN 12
started=true;
if(started) {
// Servo Setup
myservo1.attach(servPin1); // attaches the servo to the servo object
delay(2000);
return;
if (t > 26)
Serial.print(h);
Serial.print("% ");
Serial.print(t);
Serial.print(rpm);
// SMS Text
//SMS Respond
if(started) {
Serial.print(n);
char Temp[160]="Temp";
//Serial.println(SMSBuffer.compare(std::string("TEMP")) == 0);
Serial.println(smsbuffer);
Serial.println(n);
else if (strncmp(smsbuffer,"Led on", 6) == 0)
else if (strncmp(smsbuffer,"Turn left", 9) == 0)
servLeft;
Serial.print(pos1);
else if (strncmp(smsbuffer,"Turn right", 10) == 0)
servRight;
else if (strncmp(smsbuffer,"Move up", 7) == 0)
servUp;
else if (strncmp(smsbuffer,"Move down", 9) == 0)
servDown;
else if (strncmp(smsbuffer,"Servo reset", 11) == 0)
pos1 = 90;
pos2 = 90;
servReset;
void servLeft()
for(pos1 = 30; pos1 < 190; pos1 += 1) // goes from 30 degrees to 180 degrees
void servRight()
for(pos1 = 190; pos1>=30; pos1-=1) // goes from 180 degrees to 30 degrees
delay(5);
void servUp()
for(pos2 = 190; pos2>=30; pos2-=1) // goes from 180 degrees to 30 degrees
delay(5);
void servDown()
for(pos2 = 30; pos2 < 190; pos2 += 1) // goes from 30 degrees to 180 degrees
delay(5);
void servReset()
delay(5);
