SMS Relay
Hello,
VERY new to arduino, I have some very basic knowledge of programming from a course I undertook about 20 years ago.
I am attempting to have an Elegoo Uno R3 and a Sim900 GSM module control a 4 way relay via an sms message. However I am struggling to even communicate with the GSM Sheild using just about every sketch I can download.
Every time I compile the sketches I have error messages, Is there anybody who can shed light on this please.
thanks
Dave
SKETCH:
#include <SoftwareSerial.h>
// EN: String buffer for the GPRS shield message
String msg = String("");
// EN: Set to 1 when the next GPRS shield message will contains the SMS message
int SmsContentFlag = 0;
//control pins of relay.
int relay_a=4;
int relay_b=5;
int relay_c=6;
int relay_d=7;
// EN: Code PIN of the SIM card (if applied)
//String SIM_PIN_CODE = String( "XXXX" );
 Serial.begin(19200);                 // the GPRS baud rate
 // Initialize  PINs
 pinMode( 4, OUTPUT );
 pinMode( 5, OUTPUT );
 pinMode( 6, OUTPUT );
 pinMode( 7, OUTPUT );
 digitalWrite( 4, LOW );
 digitalWrite( 5, LOW );
 digitalWrite( 6, LOW );
 digitalWrite( 7, LOW );
Serial.println( "AT+CMGF=1" );
delay(200);
   char SerialInByte;
   if(Serial.available())
       SerialInByte = (unsigned char)Serial.read();
      delay(5);
       // EN: Program also listen to the GPRS shield message.
      // EN: If the message ends with <CR> then process the message
       if( SerialInByte == 13 ){
         // EN: Store the char into the message buffer
         ProcessGprsMsg();
        if( SerialInByte == 10 ){
           // EN: Skip Line feed
        else {
          // EN: store the current character in the message string buffer
          msg += String(SerialInByte);
// EN: Make action based on the content of the SMS.
//     Notice than SMS content is the result of the processing of several GPRS shield messages.
void ProcessSms( String sms ){
 if( sms.indexOf("ona") >= 0 ){
   digitalWrite( relay_a, HIGH );
  if( sms.indexOf("onb") >= 0 ){
   digitalWrite(  relay_b, HIGH );
  if( sms.indexOf("onc") >= 0 ){
   digitalWrite(  relay_c, HIGH );
 if( sms.indexOf("ond") >= 0 ){
   digitalWrite(  relay_d, HIGH );
 if( sms.indexOf("offa") >= 0 ){
   digitalWrite(  relay_a, LOW );
 if( sms.indexOf("offb") >= 0 ){
   digitalWrite(  relay_b, LOW );
 if( sms.indexOf("offc") >= 0 ){
   digitalWrite(  relay_c, LOW );
 if( sms.indexOf("offd") >= 0 ){
   digitalWrite(  relay_d, LOW );
// EN: Request Text Mode for SMS messaging
void GprsTextModeSMS(){
void GprsReadSmsStore( String SmsStorePos ){
 Serial.print( "AT+CMGR=" );
 Serial.println( SmsStorePos );
// EN: Clear the GPRS shield message buffer
void ClearGprsMsg(){
 msg = "";
// EN: interpret the GPRS shield message and act appropiately
void ProcessGprsMsg() {
 if( msg.indexOf( "Call Ready" ) >= 0 ){
  //  Serial.println( "*** GPRS Shield registered on Mobile Network ***" );
    GprsTextModeSMS();
 // EN: unsolicited message received when getting a SMS message
 if( msg.indexOf( "+CMTI" ) >= 0 ){
  //  Serial.println( "*** SMS Received ***" );
    // EN: Look for the coma in the full message (+CMTI: "SM",6)
    //     In the sample, the SMS is stored at position 6
    int iPos = msg.indexOf( "," );
    String SmsStorePos = msg.substring( iPos+1 );
  //  Serial.print( "SMS stored at " );
 //   Serial.println( SmsStorePos );
    // EN: Ask to read the SMS store
    GprsReadSmsStore( SmsStorePos );
 // EN: SMS store readed through UART (result of GprsReadSmsStore request)
 if( msg.indexOf( "+CMGR:" ) >= 0 ){
   // EN: Next message will contains the BODY of SMS
   SmsContentFlag = 1;
   // EN: Following lines are essentiel to not clear the flag!
   ClearGprsMsg();
   return;
 // EN: +CMGR message just before indicate that the following GRPS Shield message
 //     (this message) will contains the SMS body
 if( SmsContentFlag == 1 ){
//   Serial.println( "*** SMS MESSAGE CONTENT ***" );
//   Serial.println( msg );
//   Serial.println( "*** END OF SMS MESSAGE ***" );
   ProcessSms( msg );
 ClearGprsMsg();
 // EN: Always clear the flag
 SmsContentFlag = 0;
seems to upload ok, but doesnt appear to work.
any assistance would be greatly appreciated.
Dave
Take a look at the link in my footer.
And please use code tags (see 'How to use this forum') when posting code. Following forum etiquette increases your chance of getting assistance.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
Thanks guys, apologies for my lack of forum netiquette.
I have tried the SMS code as suggested by dannable, I did get the GSM shield to send 2 sms messages, but have not been able to replicate the feat.
Essentially, I want to control 4 relays depending what sms message is received, happy to pay a developer to create the code if someone wants a job :slight_smile:
thanks
If you want someone to develop it for you then post in the Gigs and Collaborations section, I’m sure someone will be happy to give you a price.
