I am able to send sms messages with the 1500. I am using speedtalk SIM. The available() function just takes forever and never returns any results...not even a value. I am using the examples.. again send works fine, but the available does not get any messages.
Is there a trick to this? I simply have the 1500, a 3.7v battery, the antenna.
Are there some commands I can run to ensure it is listening?
Sure. its just the sample. I added my arn and that's it. The available call takes minutes to return and always returns zero.. even though there are messages sent to the number from my regular phone. The send example works fine and I can get messages on my regular phone from the NB.
Any suggestions appreciated.
Also this board freezes a lot.. just hangs.. a lot.. like it gets stuck or something. I Read in the forum it is a common issue and the fix is to do some set of steps to up date the firmware.. but I assume since this board is like 1 week old it has the latest.
Any suggestions are apprecaited.
SMS receiver
This sketch, for the MKR NB 1500 board, waits for a SMS message
and displays it through the Serial port.
Circuit:
* MKR NB 1500 board
* Antenna
* SIM card that can receive SMS messages
created 25 Feb 2012
by Javier Zorzano / TD
// include the NB library
#include <MKRNB.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[] = SECRET_PINNUMBER;
const char APN[] = "mobilenet";
// initialize the library instances
NB nbAccess;
NB_SMS sms;
// Array to hold the number an SMS is retrieved from
char senderNumber[20];
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("SMS Messages Receiver");
// connection state
bool connected = false;
// Start GSM connection
while (!connected) {
if (nbAccess.begin(NULL, APN, true, true) == NB_READY) {
connected = true;
Serial.println("Not connected");
Serial.println("NB initialized");
Serial.println("Waiting for messages");
int c;
// If there are any SMSs available()
if (sms.available()) {
Serial.println("Message received from:");
// Get remote number
sms.remoteNumber(senderNumber, 20);
Serial.println(senderNumber);
// An example of message disposal
// Any messages starting with # should be discarded
if (sms.peek() == '#') {
Serial.println("Discarded SMS");
sms.flush();
// Read message bytes and print them
while ((c = sms.read()) != -1) {
Serial.print((char)c);
Serial.println("\nEND OF MESSAGE");
// Delete message from modem memory
sms.flush();
Serial.println("MESSAGE DELETED");
Sure i do! Just ->tools -> board -> board manager (or so, im not english) and then Arduino SAMD 21 and choose the version. Easy as a summer breeze.
It takes a while to change the core(up to 10 min) BE PATIENT, don't stop that procedure.
Then recompile your sketch and i think it will work.
