SMS to Morse Code
I’ve just finished a new project using a GSM shield to translate text messages to Morse Code. A shout out to learningelectronics youtube which was a very helpful reference.
The project works and I’ve posted the code for reference.
I still have a glitch I have to work out where the text repeats word by word. This is how it appears in the Serial Monitor:
SMS Messages Receiver
GSM initialized
Waiting for messages
Message received from:
+1647000000
T
Te
Tes
Test
END OF MESSAGE
MESSAGE DELETED
I think I’ll need to store the entire character string and include an ‘\n’ but every time I test something I lose the message altogether. If anyone has a suggestion on that it would be appreciated.
The code for the entire project ( minus the lowercase Morse Code):
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER ""
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];  // name for char array.  holds up to 20 characters
String mCode = "";   // string to store char input
byte mCodeLength = 0;   // byte to store length of mCode
long pause = 50;  // delay on dots ( dash*3, between letters*3, between words*7 )
char i; // stores current character
pinMode(12, OUTPUT);
mCode = "";
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("SMS Messages Receiver");
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while (notConnected) {
    if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.println("Waiting for messages");
  // If there are any SMSs available()
  if (sms.available()) { // checks to see if there is a message on the SIM
    Serial.println("Message received from:");
    // Get remote number
   sms.remoteNumber(senderNumber, 20);
   Serial.println(senderNumber);
    // An example of message disposal
    // Any messages starting with # should be discarded
    if (sms.peek() == '#') {
      Serial.println("Discarded SMS");
      sms.flush();
      while(char inChar = (char)sms.read()){
      mCode += inChar;
      Serial.println(mCode);// serial print for debugging
      doString();
    Serial.println("\nEND OF MESSAGE");
    sms.flush();  // Delete message from modem memory
    mCode = "";
    Serial.println("MESSAGE DELETED");
void dot(){
  digitalWrite(12, HIGH); // ON
  delay(pause);
  digitalWrite(12, LOW); // OFF
  delay(pause);
void dash(){
  delay(pause*3);
  delay(pause);
void doString(){
  mCodeLength = mCode.length();           // get the length of string
  for( int x=0; x<=mCodeLength; x++){  // loop this until end of string is reached
  i = mCode.charAt(x);                    // get char at pos x.  x now becomes i
  translate();                            // run through translate into Morse Code function
void translate(){
  switch(i){
    case 'A':    // if it is A ( CHAR IN '', STRING IN "" )
    dot();        // do dot
    dash();       // do dash
    case 'B':
    dash();
    dot();
    dot();
    dot();
    case 'C':
    dash();
    dot();
    dash();
    dot();
    case 'D':
    dash();
    dot();
    dot();
    case 'E':
    dot();
    case 'F':
    dot();
    dot();
    dash();
    dot();
    case 'G':
    dash();
    dash();
    dot();
    case 'H':
    dot();
    dot();
    dot();
    dot();
    case 'I':
    dot();
    dot();
    case 'J':
    dot();
    dash();
    dash();
    dash();
    case 'K':
    dash();
    dot();
    dash();
    dot();
    case 'L':
    dot();
    dash();
    dot();
    dot();
    case 'M':
    dash();
    dash();
    case 'N':
    dot();
    dash();
    case 'O':
    dash();
    dash();
    dash();
    dash();
    case 'P':
    dot();
    dash();
    dash();
    dot();
    case 'Q':
    dash();
    dash();
    dot();
    dash();
    case 'R':
    dot();
    dash();
    dot();
    case 'S':
    dot();
    dot();
    dot();
    case 'T':
    dash();
    case 'U':
    dot();
    dot();
    dash();
    case 'V':
    dot();
    dot();
    dot();
    dash();
    case 'W':
    dot();
    dash();
    dash();
    case 'X':
    dash();
    dot();
    dot();
    dash();
    case 'Y':
    dash();
    dot();
    dash();
    dash();
    case 'Z':
    dash();
    dash();
    dot();
    dot();
    case '1':
    dot();
    dash();
    dash();
    dash();
    dash();
    case '2':
    dot();
    dot();
    dash();
    dash();
    dash();
    case '3':
    dot();
    dot();
    dot();
    dash();
    dash();
    case '4':
    dot();
    dot();
    dot();
    dot();
    dash();
    case '5':
    dot();
    dot();
    dot();
    dot();
    dot();
    case '6':
    dash();
    dot();
    dot();
    dot();
    dot();
    case '7':
    dash();
    dash();
    dot();
    dot();
    dot();
    case '8':
    dash();
    dash();
    dash();
    dot();
    dot();
    case '9':
    dash();
    dash();
    dash();
    dash();
    dot();
    case '0':
    dash();
    dash();
    dash();
    dash();
    dash();
    case '!':
    dash();
    dot();
    dash();
    dash();
    dash();
    default: // between words
    delay(pause*7);
  delay(pause*3);   // delay between letters
These two statements:
      doString();
should be after the while loop.
You might eventually run into problems with garbled output caused by using Strings instead of null-terminted C strings.
Pete
That did it. Thanks el_supremo.
