SMS using 1Sheeld
Having trouble with the 1Sheeld library for SMS. I got my 1 sheeld plugged in with the UNO and got it started up but the script says 'Onesheeld needs to be declared' for some reason. I don't know what went wrong. Can anyone help? My guess is that the OneSheeld.h file should be placed somewhere. But it's with all the other .h and .cpp files so i'm confused.
The script is below.
SMS Shield Example
This example shows an application on 1Sheeld's SMS shield.
By using this example, you can send a SMS when the value
of the smartphone's temperature sensor exceeds a certain
limit.
/* Include 1Sheeld library. */
#include <OneSheeld.h>
/* Define a boolean flag. */
boolean isMessageSent = false;
/* Start communication. */
OneSheeld.begin();
/* Always check if the temperature value is larger than a certain value. /
if (TemperatureSensor.getValue() > 30)
if(!isMessageSent)
Send the SMS. /
SMS.send("1234567890","Room Temperature is higher than 30 degree!");
Set the flag. */
isMessageSent = true;
/* Reset the flag. */
No, the sketch says nothing like that. The compiler might, when compiling the sketch.
Any you have not done an adequate job of describing what you see, so we don't either.
Can anyone help?
See above.
It almost certainly should.
Where is that? \dev\NULL?
Hi to all,
Don't worry i've figured it out.
Cheers
