Good day everyone, I am new to ardunio projects. I need some help regarding my project that needs to send SMS real time,. so in my project i used RTC module for real time clock, yet once the GSM starts to send SMS the entire system hangs up stop at the time I set the GSM to send SMS
- you got your post onto a wrong sub-forum
@UKHeliBob or any mod could move it to a right sub-forum
- where is your code ? wiring ?
My apology for not posting first my code. I just tried to post my concern if there is anyone willing to help since this is my first here in the forum.
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
#include <SPI.h>
#include <SD.h>
#include <PZEM004Tv30.h>
#include <Keypad.h>
#include <SoftwareSerial.h>
#include <string.h>
PZEM004Tv30 pzem(5, 6);
SoftwareSerial mySerial(3, 2);
LiquidCrystal_I2C lcd(0x27, 20, 4);
const int chipSelect = 10;
File dataFile;
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
byte rowPins[ROWS] = {A0, A1, A2, A3}; //R1,R2,R3,R4
byte colPins[COLS] = {4, 7, 8};//C1,C2,C3,C4
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char key;
int num;
String inputString;
long inputInt;
tmElements_t tm;
const int relay = 9;
int key1 = 0;
pinMode (9, OUTPUT);
mySerial.begin(9600);
while (!Serial) ;
setSyncProvider(RTC.get);
lcd.begin();
lcd.backlight();
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
while (1);
Serial.println("card initialized.");
inputString.reserve(10); //
lcd.print ("Enter kWh:");
char key = keypad.getKey();
if (key) {
Serial.print(key);
lcd.print (key);
if (key >= '0' && key <= '9') {
inputString += key;
} else if (key == '#') {
if (inputString.length() > 0) {
inputInt = inputString.toInt();
inputString = "";
Serial.println (inputInt);
clearLCDLine(3);
clearLCDLine(0);
} else if (key == '*') {
inputString = "";
while (inputInt != 0) {
readdata();
void readdata() {
RTC.read(tm);
float voltage1 = pzem.voltage();
float current1 = pzem.current();
float power1 = pzem.power();
float energy1 = pzem.energy();
float pf = pzem.pf();
float price = ((energy1 * 2) * inputInt);
lcd.setCursor(0, 0); //LCD Display
print2digits(tm.Hour);
lcd.print (tm.Hour);
lcd.print (":");
print2digits(tm.Minute);
lcd.print (tm.Minute);
lcd.print (":");
print2digits(tm.Second);
lcd.print (tm.Second);
lcd.setCursor(10, 0); //LCD Display
lcd.print (tm.Day);
lcd.print ("/");
lcd.print (tm.Month);
lcd.print ("/");
lcd.print (tmYearToCalendar(tm.Year));
lcd.setCursor(0, 1);
lcd.print("V=");
lcd.print(voltage1, 1);
lcd.setCursor(10, 1);
lcd.print("E=");
lcd.print((energy1 * 2), 2);
lcd.setCursor(0, 2);
lcd.print("A=");
lcd.print(current1 * 2);
lcd.setCursor(10, 2);
lcd.print("W=");
lcd.print((power1 * 2), 1);
lcd.setCursor(0, 3);
lcd.print("$=");
lcd.print(price, 2);
lcd.setCursor(10, 3);
lcd.print("D=");
lcd.setCursor(12, 3);
lcd.print(inputInt);
int time1 = tm.Hour;
int time2 = tm.Minute;
int time3 = tm.Second;
if (time3 == 0) { //(time1 == 8 && time2 == 00 ) &&
char charVal[8]; //temporarily holds data from vals
String stringVal = "";
dtostrf(price, 4, 4, charVal);
char message[15] = "Your bill is: ";
strncat(message, charVal, sizeof(charVal));
mySerial.println("AT");
updateSerial();
mySerial.println("AT+CMGF=1"); // Configuring TEXT mode
updateSerial();
mySerial.println("AT+CMGS=\"+639059256120\"");//change ZZ with country code and xxxxxxxxxxx with phone number to sms
updateSerial();
mySerial.print(message); //text content
updateSerial();
mySerial.write((char)26);
delay (1000);
dataFile = SD.open("datalog.txt", FILE_WRITE);
dataFile.print("Date (D/M/Y) = "); //SD Card
dataFile.print(tm.Day);
dataFile.print("/");
dataFile.print(tm.Month);
dataFile.println (tmYearToCalendar(tm.Year));
dataFile.print("Voltage: "); //SD Card
dataFile.print(voltage1);
dataFile.print("Energy: ");
dataFile.print(energy1 * 2);
dataFile.print("Dist.Cost: ");
dataFile.println();
dataFile.print("Current: "); //SD Card
dataFile.print(current1 * 2);
dataFile.print("Power: ");
dataFile.print(power1 * 2);
dataFile.print("Bill: ");
dataFile.println(price);
dataFile.println("\n");
dataFile.close();
if (pzem.voltage() >= 270 || pzem.voltage() <= 190) {
digitalWrite (9, HIGH);
delay (9000);
dataFile.println("----------OVERLOAD-----------");
dataFile.print("Time = "); //SD Card
dataFile.print (tm.Hour);
dataFile.print(":");
dataFile.print (tm.Minute);
dataFile.print (tm.Second);
dataFile.close();
else {
digitalWrite (9, LOW);
void updateSerial() {
while (Serial.available()) {
mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
while (mySerial.available()) {
Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
void print2digits(int number) {
if (number >= 0 && number < 10) {
lcd.print ('0');
dataFile.print('0');
void clearLCDLine(int line) {
lcd.setCursor(0, line);
for (int n = 0; n < 20; n++) {
lcd.print(" ");
I set the code to send SMS on the data recorder by the sensor every minute. yet the code will function only up to 3 to 4 SMS sent, for the 5th sent the system will hang up at exactly a minute. my phone will receive the SMS yet the display of my arduino will hang up and stop everything including the sending of SMS
perhaps one of the array here overflows ?
try replacing that whole code block with this
String message = "Your bill is: " + String(price,2);
Thanks for your suggestion Kassim. I will try this modification and feedback later
hello kassim, the code now works well but the text message has no content. And I set the GSM to send SMS at exactly 00 seconds, yet there are times the clock skips this
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project See About the Installation & Troubleshooting category.
Thank you sterretje,.
have you posted that code?
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <Keypad.h>
#include <string.h>
File dataFile;
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
char key;
int num;
String inputString;
long inputInt;
tmElements_t tm;
int key1 = 0;
while (!Serial) ;
lcd.begin();
lcd.backlight();
while (1);
if (key) {
Serial.print(key);
lcd.print (key);
inputString += key;
inputString = "";
clearLCDLine(3);
clearLCDLine(0);
inputString = "";
readdata();
void readdata() {
RTC.read(tm);
lcd.print (":");
lcd.print (":");
lcd.print (tm.Day);
lcd.print ("/");
lcd.print ("/");
lcd.print("V=");
lcd.print("E=");
lcd.print("A=");
lcd.print("W=");
lcd.print("$=");
lcd.print("D=");
// char charVal[8]; //temporarily holds data from vals
// String stringVal = "";
// dtostrf(price, 4, 4, charVal);
// char message[15] = "Your bill is: ";
// strncat(message, charVal, sizeof(charVal));
updateSerial();
updateSerial();
updateSerial();
updateSerial();
delay (1000);
dataFile.println();
dataFile.close();
delay (9000);
dataFile.close();
else {
lcd.print ('0');
lcd.print(" ");
the sim 800L cannot send SMS using variable. I received empty message
that is why from my previous code i used array
