SMSrequest cannot be used as a function
Hello I am writing a code that is able to command the GSM module (SIM900A) to send an SMS once I have send the appropriate text message to it. I got this code from a YouTube tutorial I watched, I have rewritten it a bit to match the one I need in my project.
this is the code
#include <SoftwareSerial.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2                // Data wire is plugged into digital pin 2 on the Arduino
OneWire oneWire(ONE_WIRE_BUS);        // Setup a oneWire instance to communicate with any OneWire device
DallasTemperature sensors(&oneWire);  // Pass oneWire reference to DallasTemperature library
SoftwareSerial myGSM(8, 9);
float calibration_value = 21.34 + 1.1;
int phval = 0;
unsigned long int avgval;
int buffer_arr[10], temp;
float ph_act;
#define MPLa 4  //left peristaltic motor 1st pin
#define MPLb 5  //left peristaltic  motor 2nd pin
#define MPRa 6  //right peristaltic  motor 1st pin
#define MPRb 7  //right peristaltic motor 2nd pin
#define MWa 3   //right water  motor 1st pin
#define MWb 10  //right water motor 2nd pin
char incomingChar;
int readData;
int SMSRequest;
int SendMessageph;
//pin used, 2-temp, 8,9-gsm, a0-ph, hydropump-3, waterpump-4
  sensors.begin();
  myGSM.begin(19200);
  Serial.begin(19200);  // initialize serial monitor with 19200 baud
  delay(100);
  myGSM.println("AT+CMGF=1");
  delay(100);
  // Set module to send SMS data to serial out upon receipt
  myGSM.print("AT+CMGF=1,1,0,0,0");
  delay(100);
  pinMode(MPLa, OUTPUT);  // Set Motor Pins As O/P
  pinMode(MPLb, OUTPUT);
  pinMode(MPRa, OUTPUT);
  pinMode(MPRb, OUTPUT);
  pinMode(MWa, OUTPUT);
  pinMode(MWb, OUTPUT);
  digitalWrite(MWa, LOW);
  digitalWrite(MWb, HIGH);
  sensors.requestTemperatures();
  float t = sensors.getTempCByIndex(0);  //print the temperature in Celsius
  Serial.print("Temperature: ");
  Serial.print(t);  //Serial.print((char)176);//shows degrees character
  Serial.print("C");
  delay(100);
  for (int i = 0; i < 10; i++) {
    buffer_arr[i] = analogRead(A0);
    delay(30);
  for (int i = 0; i < 9; i++) {
    for (int j = i + 1; j < 10; j++) {
      if (buffer_arr[i] > buffer_arr[j]) {
        temp = buffer_arr[i];
        buffer_arr[i] = buffer_arr[j];
        buffer_arr[j] = temp;
  avgval = 0;
  for (int i = 2; i < 8; i++)
    avgval += buffer_arr[i];
  float volt = (float)avgval * 5.0 / 1024 / 6;
  float ph_act = -5.70 * volt + calibration_value;
  Serial.println(" ");
  delay(100);
  Serial.print("PH Val: ");
  delay(100);
  Serial.print(ph_act);
  delay(100);
  if (t > 30) {
      myGSM.println("AT+CMGF=1");  //AT command that sets the gsm module to text mode
      delay(100);
      myGSM.println("AT+CMGS=\"09193280950\"\r");
      delay(100);
      myGSM.print("TEMPERATURE ALERT:");  //sms you want to send
      delay(100);
      myGSM.print(t);  //sms you want to send
      delay(100);
      //myGSM.print((char)176); //sms you want to send
      //delay(100);
      myGSM.print("C");  //sms you want to send
      delay(100);
      myGSM.println((char)26);  //ascii code of ctrl z
      delay(100);
    delay(4000);
  if (ph_act < 8.5) {
    delay(100);
    delay(100);
    myGSM.println("PH LEVEL ALERT:");  //sms you want to send
    delay(100);
    myGSM.println(ph_act);  //sms you want to send
    delay(100);
    delay(100);
  else if (ph_act > 20) {
    digitalWrite(MWb, LOW);
    delay(4000);
      delay(100);
      delay(100);
      myGSM.println("Water Tank: Empty");  //sms you want to send
      delay(100);
      delay(100);
    delay(4000);
  if (SMSRequest ()) {
    if (readData ()) {
      delay(10);
        delay(10);
        delay(100);
        delay(100);
        // REPLACE WITH YOUR OWN SMS MESSAGE CONTENT
        String dataMessage = ("Temperature: " + String(t) + "*C " + " pH: " + String(ph_act) + "level");
        // Uncomment to change message with farenheit temperature
        // String dataMessage = ("Temperature: " + String(f) + "*F " + " Humidity: " + String(h) + "%");
        // Send the SMS text message
        myGSM.println(dataMessage);
        delay(100);
        // End AT command with a ^Z, ASCII code 26
        delay(100);
        myGSM.println();
        // Give module time to send SMS
        delay(5000);
      delay(10);
    void readData() {
      //Read temperature
      //Read pH
      // Check if any reads failed and exit early (to try again).
      if (isnan(t) || isnan(ph_act)) {
        Serial.println("Failed to read!");
        return false;
      Serial.print("pH Level: ");
      Serial.print(t);
      Serial.print(" *C ");
      return true;
    void SMSRequest() {
      if (myGSM.available() > 0) {
        incomingChar = myGSM.read();
        if (incomingChar == 'S') {
          delay(10);
          Serial.print(incomingChar);
          if (incomingChar == 'T') {
            delay(10);
            if (incomingChar == 'A') {
              delay(10);
              incomingChar = SIM900.read();
                delay(10);
                if (incomingChar == 'E') {
                  delay(10);
                  Serial.print("...Request Received \n");
                  return true;
      return false;
I have four error message I keep getting, I am unsure how to solve them.
This is the error message
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino: In function 'void loop()':
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:128:19: error: 'SMSRequest' cannot be used as a function
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:129:19: error: 'readData' cannot be used as a function
     if (readData ()) {
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:154:21: error: a function-definition is not allowed here before '{' token
     void readData() {
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:176:23: error: a function-definition is not allowed here before '{' token
     void SMSRequest() {
exit status 1
Compilation error: 'SMSRequest' cannot be used as a function
I'm a newbie and this is for a school project. I hope someone can help me! Any tips to become better would also be appreciated. Thank you in advance!
SMSRequest is declared as an int and a function. Change the name of one of them
To add to the problems the closing brace for the loop() function is missing or in the wrong place, as is a second one Presumably it should end before the definition of the readData() function
If you Auto format the code in the IDE the problem with the loop() function shows up immediately because the definition of readData() does not start on the left margin of the editor and the closing brace of the loop() function shows its position at the end of the code with 2 closing braces on the same line
What do you mean about the SMSrequest being an int and a function? How can I change them? Thanks!
I have fixed the issue about the missing closing brace for the loop(), thanks! But, I still keep getting issues about "a function-definition is not allowed here before '{' token void SMSRequest() {
^ " same with the void readData(), what does that mean? Thanks!
void SMSRequest()
and
int SMSRequest;
Just give one or both a different name but note the other problems with braces that I pointed out
Please post your revised sketch in a new reply
I changed the "if (SMSrequest())" to "if (SMSrequestStatus())" same with readData, I changed the name in the void too, now it says "SMSrequest Status was not declared in this scope" same with readData, and I have yet to figure out how to solve the "a function-definition is not allowed here before'{' token "
here is the revised code
int phval = 0;
float ph_act;
char incomingChar;
int readData;
int SMSRequest;
int SendMessageph;
  sensors.begin();
  myGSM.begin(19200);
  delay(100);
  delay(100);
  delay(100);
  Serial.print("C");
  delay(100);
    delay(30);
  avgval = 0;
  delay(100);
  delay(100);
  delay(100);
  if (t > 30) {
      delay(100);
      delay(100);
      delay(100);
      delay(100);
      //delay(100);
      delay(100);
      delay(100);
    delay(4000);
  if (ph_act < 8.5) {
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(4000);
      delay(100);
      delay(100);
      delay(100);
      delay(100);
    delay(4000);
  if (SMSRequestStatus()) {
    if (readDataStatus()) {
      delay(10);
        delay(10);
        delay(100);
        delay(100);
        delay(100);
        delay(100);
        myGSM.println();
        delay(5000);
      delay(10);
    void readDataStatus() {
      //Read temperature
      //Read pH
      // Uncomment to compute temperature values in Fahrenheit
      //f = dht.computeHeatIndex(f,h,false);
        return false;
      Serial.print(t);
      return true;
    void SMSRequestStatus() {
          delay(10);
            delay(10);
              delay(10);
                delay(10);
                  delay(10);
                  return true;
      return false;
and here is the new error message
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:128:7: error: 'SMSRequestStatus' was not declared in this scope
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:128:7: note: suggested alternative: 'SMSRequest'
       SMSRequest
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:129:9: error: 'readDataStatus' was not declared in this scope
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:129:9: note: suggested alternative: 'readData'
         readData
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:155:27: error: a function-definition is not allowed here before '{' token
C:\Users\JIZELL AIRA\Downloads\sketch_oct07c\sketch_oct07c.ino:177:29: error: a function-definition is not allowed here before '{' token
exit status 1
Compilation error: 'SMSRequestStatus' was not declared in this scope
Thank you for the help! :slight_smile:
You still have a problem with extra, missing of misplaced braces
Look at this portion of the code you posted
      //Read temperature
Why doesn't the function definition start on the left margin ?
Answer, because the loop() function does not end where it should, probably immediately before that function definition.
Fix that ( and remove the extra brace at the end of the sketch ) and another error will rear its ugly head
The SMSRequestStatus() function is declared void, ie it does not return a value. However, in this line
You try to test the value that it returns
Oh my God I finally was able to fixed it! I changed the void to bool since it was recommended in the error message and it worked! Although, I'm not sure if that's correct, is it? Anyways, I also was able to fixed the missing brace to end the loop()! Thank you so much for the help! I'll test out the code to see if it's working as intended. :slight_smile:
Well done, at least it compiles
Yes, changing the return type of the function to bool or boolean was the right thing to do as the return value is either true or false
Going back to the start of this topic, do you understand what caused the problems and why the suggested changes fixed them ?
Yes! I understood it a bit. I realized my mistake of misplacing or missing brackets as they are very important in coding and the importance of knowing what type of function to use!
