Good evening, I'm following the example ( Arduino Playground - HomePage ) for demultiplexing 8 buttons with a 165 chip.
Works like a charm except for a little weird issue:
The last bit is always inverted, If I press that button then it goes to LOW.
Tried switching the poles and replacing the button but nothing changes, so I guess it is something in the code but can't figure what.
Just one chip so I set that one to 1, basically I modified only this line and those for arduino pins
Also added missing pins in the image
* SN74HC165N_shift_reg
* Program to shift in the bit values from a SN74HC165N 8-bit
* parallel-in/serial-out shift register.
* This sketch demonstrates reading in 16 digital states from a
* pair of daisy-chained SN74HC165N shift registers while using
* only 4 digital pins on the Arduino.
* You can daisy-chain these chips by connecting the serial-out
* (Q7 pin) on one shift register to the serial-in (Ds pin) of
* the other.
* Of course you can daisy chain as many as you like while still
* using only 4 Arduino pins (though you would have to process
* them 4 at a time into separate unsigned long variables).
/* How many shift register chips are daisy-chained.
#define NUMBER_OF_SHIFT_CHIPS 1
/* Width of data (how many ext lines).
#define DATA_WIDTH NUMBER_OF_SHIFT_CHIPS * 8
/* Width of pulse to trigger the shift register to read and latch.
#define PULSE_WIDTH_USEC 5
/* Optional delay between shift register reads.
#define POLL_DELAY_MSEC 1
/* You will need to change the "int" to "long" If the
* NUMBER_OF_SHIFT_CHIPS is higher than 2.
#define BYTES_VAL_T unsigned int
int ploadPin = 12; // Connects to Parallel load pin the 165
int clockEnablePin = 10; // Connects to Clock Enable pin the 165
int dataPin = 11; // Connects to the Q7 pin the 165
int clockPin = 10; // Connects to the Clock pin the 165
BYTES_VAL_T pinValues;
BYTES_VAL_T oldPinValues;
/* This function is essentially a "shift-in" routine reading the
* serial Data from the shift register chips and representing
* the state of those pins in an unsigned integer (or long).
BYTES_VAL_T read_shift_regs()
long bitVal;
BYTES_VAL_T bytesVal = 0;
/* Trigger a parallel Load to latch the state of the data lines,
digitalWrite(clockEnablePin, HIGH);
digitalWrite(ploadPin, LOW);
delayMicroseconds(PULSE_WIDTH_USEC);
digitalWrite(ploadPin, HIGH);
digitalWrite(clockEnablePin, LOW);
/* Loop to read each bit value from the serial out line
* of the SN74HC165N.
for(int i = 0; i < DATA_WIDTH; i++)
bitVal = digitalRead(dataPin);
/* Set the corresponding bit in bytesVal.
bytesVal |= (bitVal << ((DATA_WIDTH-1) - i));
/* Pulse the Clock (rising edge shifts the next bit).
digitalWrite(clockPin, HIGH);
digitalWrite(clockPin, LOW);
return(bytesVal);
/* Dump the list of zones along with their current status.
void display_pin_values()
Serial.print("Pin States:\r\n");
Serial.print(" Pin-");
Serial.print(i);
Serial.print(": ");
if((pinValues >> i) & 1)
Serial.print("HIGH");
Serial.print("LOW");
Serial.print("\r\n");
/* Initialize our digital pins...
pinMode(ploadPin, OUTPUT);
pinMode(clockEnablePin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, INPUT);
/* Read in and display the pin states at startup.
pinValues = read_shift_regs();
display_pin_values();
oldPinValues = pinValues;
/* Read the state of all zones.
/* If there was a chage in state, display which ones changed.
if(pinValues != oldPinValues)
Serial.print("*Pin value change detected*\r\n");
delay(POLL_DELAY_MSEC);
Grumpy_Mike:
By default do you mean with nothing connected? Without anything connected to a pin you can get any value but most likely you will get a high.
No, I mean with the buttons not being pressed.
All the pins have a button/switch with a pull-up resistor.
Grumpy_Mike:
Can you post a photo showing your wiring, not more than 1000 pixels wide.
I really doubt I can get something useful with the 320p of my phone.
The way you drew your wiring they would be high by default. I'm not sure what else you are expecting.
You have 8 x 4.7k resistors, right? And each one is connected between the pin and 5V? And the switch is connected between the pin and Gnd? And the switches work? Try measuring the voltage on each pin and confirm whether or not it is what the code reports.
