Snake Duino Not Compiling
I've found a Snake game online and for some reason it is not compiling, I think it is something to do with the installed libraries but i'm not sure exactly what.
Here's the Code:
* "THE BEER-WARE LICENSE" (Revision 42):
* <phk@FreeBSD.ORG> wrote this file. As long as you retain this notice you
* can do whatever you want with this stuff. If we meet some day, and you think
* this stuff is worth it, you can buy me a beer in return Poul-Henning Kamp
*  Snake Duino v1
* Nokia 5110 LCD attached to pins 7, 6, 5, 4, 3
* Active Buzzer attached to pin 8
* Push-buttons attached to pins A2, A3, A4, A5
* Inspirated in Snake v1.0, Ouarrak Ayoub
* http://pastebin.com/iAVt9AGJ
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
/* pins */
#define SPEAKER_PIN 8
/* constants */
#define UP    1
#define RIGHT 2
#define DOWN  3
#define LEFT  4
/* frame size */
#define MAX_WIDTH  84
#define MAX_HEIGHT 48
/* defaults */
#define ORIGINAL  false
#define SNAKE_LEN 10
/* lcd display */
Adafruit_PCD8544 lcd = Adafruit_PCD8544(7, 6, 5, 4, 3);
int x = 5, y = 5;
/* snake face */
int xC, yC;
/* position food */
int xFood = 0, yFood = 0;
int point = 0, points = 10;
/* directions */
int dr = 0, dc = 1, i;
boolean left = false, right = true, up = false, down = false;
// vetor containing the coordinates of the individual parts
// of the snake {cols[0], row[0]}, corresponding to the head
int snakeCols[260];
// Vector containing the coordinates of the individual parts
// of the snake {cols [snake_lenght], row [snake_lenght]} correspond to the tail
int snakeRow[260];
/* snake lenght */
int snakeLen = SNAKE_LEN;
int level = 0, time = 20;
// sensors input
int btUp, btDown, btRight, btLeft;
void(* reset)(void) = 0;
 * setup
  randomSeed(analogRead(1));
  lcd.begin();
  pinMode(SPEAKER_PIN, OUTPUT);
  digitalWrite(SPEAKER_PIN, LOW);
  xFood = lcd.width()  / 2;
  yFood = lcd.height() / 2;
  intro();
 *  loop
  snake();
 * snake
void snake()
  xC = snakeCols[0];
  yC = snakeRow[0];
  if(point == 0 || point == points)
    level++;
    printLevel();
  lcd.clearDisplay();
  btUp    = analogRead(A2);
  btLeft  = analogRead(A5);
  btDown  = analogRead(A4);
  btRight = analogRead(A3);
  moveSnake(btLeft, btRight, btUp, btDown);
  // the snake has eaten the food (right or left)
  for(int i=0; i < 3; i++)
    // control the snake's head (x) with x-coordinates of the food
    if((xC+1 == xFood) or (xC == xFood+1))
      // control the snake's head (y) with y-coordinates of the food
      if((yC == yFood) or (yC+1 == yFood) or (yC == yFood+1))
        eatFood();
    // the snake has eaten the food (from above or from bellow)
    if((yC == yFood) or (yC == yFood+i))
      if((xC == xFood) or (xC+i == xFood) or (xC == xFood+i))
        eatFood();
  /* LEFT */
  if(left == true)
    // snake touches the left wall
    if(xC == 1) gameover();
    if(xC  > 1) drawSnake();
  /* RIGHT */
  if(right == true)
    // snake touches the top wall
    if(xC == MAX_WIDTH-1) gameover();
    if(xC  < MAX_WIDTH-1) drawSnake();
  /* UP */
  if(up == true)
    // snake touches the above wall
    if(yC == 1) gameover();
    if(yC  > 1) drawSnake();
  /* DOWN */
  if(down == true)
    // snake touches the ground
    if(yC == MAX_HEIGHT-1) gameover();
    if(yC  < MAX_HEIGHT-1) drawSnake();
  delay(time);
 * eatFood
void eatFood()
  beep(2000, 10);
  // increase the point and snake lenght
  point++;
  snakeLen += 2;
  // new coordinates food randonly
  xFood = random(1, 80);
  yFood = random(1, 46);
  drawSnake();
 * drawSnake
void drawSnake()
  lcd.drawRect(0, 0, MAX_WIDTH, MAX_HEIGHT, BLACK);
  for(int i = snakeLen; i > 0; i--)
    lcd.drawCircle(snakeCols[i], snakeRow[i], 1, BLACK);
  lcd.fillRect(xFood, yFood, 3, 3, BLACK);
  lcd.display();
    snakeRow[i]  = snakeRow[i - 1];
    snakeCols[i] = snakeCols[i - 1];
  snakeRow[0]  += dr;
  snakeCols[0] += dc;
 * moveSnake
void moveSnake(int k, int l, int m, int j)
  /* LEFT */
  if(k > 900 and right == false)
    if((xC > 0 or xC <= lcd.width() - xC))
      direc(LEFT);
  /* RIGHT */
  if(l > 900 and left == false)
      direc(RIGHT);
  /* UP */
  if(m > 900 and down == false)
    if((yC > 0 or yC <= lcd.height() - yC))
      direc(UP);
Here is the error Message:
SnakeDuino:42: error: 'Adafruit_PCD8544' does not name a type
C:\Users\lachi\AppData\Local\Temp\Temp2_snake-duino-v1-master.zip\snake-duino-v1-master\SnakeDuino\SnakeDuino.ino: In function 'void setup()':
SnakeDuino:86: error: 'lcd' was not declared in this scope
   lcd.begin();
C:\Users\lachi\AppData\Local\Temp\Temp2_snake-duino-v1-master.zip\snake-duino-v1-master\SnakeDuino\SnakeDuino.ino: In function 'void snake()':
SnakeDuino:119: error: 'lcd' was not declared in this scope
   lcd.clearDisplay();
C:\Users\lachi\AppData\Local\Temp\Temp2_snake-duino-v1-master.zip\snake-duino-v1-master\SnakeDuino\SnakeDuino.ino: In function 'void drawSnake()':
SnakeDuino:209: error: 'lcd' was not declared in this scope
SnakeDuino:209: error: 'BLACK' was not declared in this scope
C:\Users\lachi\AppData\Local\Temp\Temp2_snake-duino-v1-master.zip\snake-duino-v1-master\SnakeDuino\SnakeDuino.ino: In function 'void moveSnake(int, int, int, int)':
SnakeDuino:237: error: 'lcd' was not declared in this scope
SnakeDuino:244: error: 'lcd' was not declared in this scope
SnakeDuino:251: error: 'lcd' was not declared in this scope
SnakeDuino:258: error: 'lcd' was not declared in this scope
     if((yC > 0 or yC <= lcd.height() - yC));
C:\Users\lachi\AppData\Local\Temp\Temp2_snake-duino-v1-master.zip\snake-duino-v1-master\SnakeDuino\SnakeDuino.ino: In function 'void showPause()':
SnakeDuino:268: error: 'lcd' was not declared in this scope
   lcd.clearDisplay();
SnakeDuino:270: error: 'BLACK' was not declared in this scope
   lcd.setTextColor(BLACK);
C:\Users\lachi\AppData\Local\Temp\Temp2_snake-duino-v1-master.zip\snake-duino-v1-master\SnakeDuino\SnakeDuino.ino: In function 'void printLevel()':
SnakeDuino:290: error: 'lcd' was not declared in this scope
     lcd.clearDisplay();
C:\Users\lachi\AppData\Local\Temp\Temp2_snake-duino-v1-master.zip\snake-duino-v1-master\SnakeDuino\SnakeDuino.ino: In function 'void gameover()':
SnakeDuino:342: error: 'lcd' was not declared in this scope
   lcd.clearDisplay();
C:\Users\lachi\AppData\Local\Temp\Temp2_snake-duino-v1-master.zip\snake-duino-v1-master\SnakeDuino\SnakeDuino.ino: In function 'void intro()':
SnakeDuino:395: error: 'lcd' was not declared in this scope
   lcd.clearDisplay();
SnakeDuino:399: error: 'WHITE' was not declared in this scope
   lcd.setTextColor(WHITE, BLACK);
SnakeDuino:399: error: 'BLACK' was not declared in this scope
exit status 1
Any help with this would be greatly appreciated
Are those ALL of the messages? It looks to me like you didn't copy all of the error messages - specifically the one(s) that said that the preprocessor couldn't find all the required header files, because you haven't installed all the required libraries.
PaulS:
No those were all of the error messages that were displayed
For some bizarre reason, I happen to have the Adafruit libraries properly installed. When I compile your code, I get a bunch of different messages:
Arduino: 1.8.2 (Windows 7), TD: 1.36, Board: "Arduino/Genuino Uno"
C:\Users\pjs9486\Documents\Arduino\Crap\Crap.ino\sketch_feb21a\sketch_feb21a.ino: In function 'void setup()':
sketch_feb21a:95: error: 'intro' was not declared in this scope
intro();
C:\Users\pjs9486\Documents\Arduino\Crap\Crap.ino\sketch_feb21a\sketch_feb21a.ino: In function 'void snake()':
sketch_feb21a:117: error: 'printLevel' was not declared in this scope
printLevel();
sketch_feb21a:156: error: 'gameover' was not declared in this scope
sketch_feb21a:164: error: 'gameover' was not declared in this scope
sketch_feb21a:172: error: 'gameover' was not declared in this scope
sketch_feb21a:180: error: 'gameover' was not declared in this scope
C:\Users\pjs9486\Documents\Arduino\Crap\Crap.ino\sketch_feb21a\sketch_feb21a.ino: In function 'void eatFood()':
sketch_feb21a:192: error: 'beep' was not declared in this scope
beep(2000, 10);
C:\Users\pjs9486\Documents\Arduino\Crap\Crap.ino\sketch_feb21a\sketch_feb21a.ino: In function 'void moveSnake(int, int, int, int)':
sketch_feb21a:239: error: 'direc' was not declared in this scope
direc(LEFT);
sketch_feb21a:246: error: 'direc' was not declared in this scope
direc(RIGHT);
sketch_feb21a:253: error: 'direc' was not declared in this scope
direc(UP);
sketch_feb21a:254: error: expected '}' at end of input
exit status 1
option enabled in File -> Preferences.
Notice how MY output shows the version of the IDE, the board I am compiling for, the operating system, etc. Compare that to your "complete" output, which doesn't have those details.
Perhaps you should follow the last bit of advice in my output.
I checked again and there is no description of the IDE or anything. I'm still unsure of what is causing it though as that is all that it is showing.
