Hello,
I want to build a SNES Controller that I can hook up to my Wii as Classic Controller, so I began reading in the SNES Controller which works just fine...
then I started looking how to communicate with the Wiimote and I found this lib http://gitorious.org/randomstuff/arduino-wiimote in the Playground...
But when I use it with my Sketch it makes weird things....
After uploading it, the Wii akts like the "Home Button" got pressed... after that it keeps pressing the Minus Button... I think it is the Minus Button cause I can not scroll Forward through the Channels.
Sometimes I can scroll through the Channels but when pressing Start on the SNES Controller it scrolls two times forward and then it keeps scrolling backwards in the channels...
This is my Sketch:
#include <Wire.h> // This seems redundant, but we need to declare this
// dependency in the pde file or else it won't be included
// in the build.
#include "wiimote.h"
// Wiimote Lib found in Arduino Playground
// SNES Lib based on Values found online
// Controller buttons
#define SNES_B 32768 // 1000000000000000
#define SNES_Y 16384 // 0100000000000000
#define SNES_SELECT 8192 // 0010000000000000
#define SNES_START 4096 // 0001000000000000
#define SNES_UP 2048 // 0000100000000000
#define SNES_DOWN 1024 // 0000010000000000
#define SNES_LEFT 512 // 0000001000000000
#define SNES_RIGHT 256 // 0000000100000000
#define SNES_A 128 // 0000000010000000
#define SNES_X 64 // 0000000001000000
#define SNES_L 32 // 0000000000100000
#define SNES_R 16 // 0000000000010000
//SNES Pins at Arduino
int SNES_LatchPin = 2; // Latch
int SNES_ClockPin = 3; // Clock
int SNES_DataPin = 4; // Serial Data
// Here's how to connect the Arduino to the Wiimote:
// * Arduino Wiimote
// * GND GND (white cable)
// * AREF 3.3V (red cable)
// * A4 SDA (green cable)
// * A5 SCL (yellow cable)
// Current controller data
unsigned int ControllerData = 0;
// Classic Controller Buttons
int bdl = 0; // D-Pad Left state
int bdr = 0; // D-Pad Right state
int bdu = 0; // D-Pad Up state
int bdd = 0; // D-Pad Down state
int ba = 0; // A button state
int bb = 0; // B button state
int bx = 0; // X button state
int by = 0; // Y button state
int bl = 0; // L button state
int br = 0; // R button state
int bm = 0; // MINUS button state
int bp = 0; // PLUS button state
int bhome = 0; // HOME button state
int bzl = 0; // ZL button state
int bzr = 0; // ZR button state
* Analog Buttons.
* They are initialized with center values from the calibration buffer.
byte lx = calbuf[2]>>2;
byte ly = calbuf[5]>>2;
byte rx = calbuf[8]>>3;
byte ry = calbuf[11]>>3;
// Wiimote button data stream
byte *stream_callback(byte *buffer)
wiimote_write_buffer(buffer, bdl, bdr, bdu, bdd, ba, bb, bx, by, bl, br, bm, bp, bhome, lx, ly, rx, ry, bzl, bzr);
return buffer;
// Setup the controller and serial output
pinMode(SNES_LatchPin,OUTPUT);
pinMode(SNES_ClockPin,OUTPUT);
pinMode(SNES_DataPin,INPUT);
digitalWrite(SNES_LatchPin,HIGH);
digitalWrite(SNES_ClockPin,HIGH);
// Prepare wiimote communications
wiimote_stream = stream_callback;
wiimote_init();
// Read controller
void controllerRead() {
// Reset controller states and data
ControllerData = 0;
digitalWrite(SNES_LatchPin,LOW);
// Controller needs to latch the state of all buttons
delayMicroseconds(1);
delayMicroseconds(6);
// Read controller data (initial reading)
ControllerData = digitalRead(SNES_DataPin);
// Send 16 clock pulses, one for each button.
for (int i = 0; i < 16; i ++) {
digitalWrite(SNES_ClockPin,LOW);
ControllerData = ControllerData << 1;
ControllerData = ControllerData + digitalRead(SNES_DataPin) ;
// Do a NOT, so '1' will be pressed buttons and '0' to the rest
ControllerData = ~ControllerData;
//Main Program
controllerRead();
// Debuging
//Serial.println(~ControllerData, BIN);
if (ControllerData != 0) {
Serial.print("Pressed buttons:");
if (ControllerData & SNES_B) {
Serial.print(" B");
bb = HIGH;
if (ControllerData & SNES_Y) {
Serial.print(" Y");
by = HIGH;
if (ControllerData & SNES_SELECT) {
Serial.print(" SELECT");
bm = HIGH;
if (ControllerData & SNES_START) {
Serial.print(" START");
bp = HIGH;
if (ControllerData & SNES_UP) {
Serial.print(" UP");
bdu = HIGH;
if (ControllerData & SNES_DOWN) {
Serial.print(" DOWN");
bdd = HIGH;
if (ControllerData & SNES_LEFT) {
Serial.print(" LEFT");
bdl = HIGH;
if (ControllerData & SNES_RIGHT) {
Serial.print(" RIGHT");
bdr = HIGH;
if (ControllerData & SNES_A) {
Serial.print(" A");
ba = HIGH;
if (ControllerData & SNES_X) {
Serial.print(" X");
bx = HIGH;
if (ControllerData & SNES_L) {
Serial.print(" L");
bzl = HIGH;
if (ControllerData & SNES_R) {
Serial.print(" R");
bzr = HIGH;
Serial.println("");
delay(50);
Is there some error in my sketch that I dont see? Or is it the Lib?
