Hi all,
I have a controller board and a i2c touch controller. The board is allmost dead. I can probably get it running the touch.
Now i want to know if i can still use this touch controller so i hooked it up to my Arduino mini pro and found something on address 127 at 800khz. This might be the controller or the touch controller.
After this is tried the example below but no results.
- something might be wrong with the code im using like the speed (i dont know how to set this)
- if this is the touch controller on 127, it might need to be configured at startup, im not getting data by touching it.
I will try to get the board working so i can check for data with my scope.
Any toughts or suggestions?
// Wire Slave Receiver
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Receives data as an I2C/TWI slave device
// Refer to the "Wire Master Writer" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <Wire.h>
Wire.begin(8); // join i2c bus with address #8
Wire.onReceive(receiveEvent); // register event
Serial.begin(9600); // start serial for output
delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
while (1 < Wire.available()) { // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
