Hi. I am trying to sniff Wi-Fi probe requests with a NodeMCU 1.0 (ESP-12E module) and then immediately upload the data (mac_address and RSSI) to a PHP script to store it in a MySQL database. The sequence would be: Detect probe request, fetch mac_address and RSSI, upload to PHP script, continue listening for more probe requests. I am working with code from: https://www.hackster.io/rayburne/esp8266-mini-sniff-f6b93a and https://www.hackster.io/kosme/esp8266-sniffer-9e4770. Below is what I currently have:
File below: MACSniff.io
// by Ray Burnette 20161013 compiled on Linux 16.3 using Arduino 1.6.12
//Hacked by Kosme 20170520 compiled on Ubuntu 14.04 using Arduino 1.6.11
#include <ESP8266WiFi.h>
#include "./functions.h"
#define disable 0
#define enable 1
unsigned int channel = 1;
Serial.begin(57600);
Serial.printf("\n\nSDK version:%s\n\r", system_get_sdk_version());
wifi_set_opmode(STATION_MODE); // Promiscuous works only with station mode
wifi_set_channel(channel);
wifi_promiscuous_enable(disable);
wifi_set_promiscuous_rx_cb(promisc_cb); // Set up promiscuous callback
wifi_promiscuous_enable(enable);
channel = 1;
while (true) {
nothing_new++; // Array is not finite, check bounds and adjust if required
if (nothing_new > 100) {
nothing_new = 0;
channel++;
if (channel == 15) break; // Only scan channels 1 to 14
delay(1); // critical processing timeslice for NONOS SDK! No delay(0) yield()
File below: functions.h
// This-->tab == "functions.h"
// Expose Espressif SDK functionality
extern "C" {
#include "user_interface.h"
typedef void (*freedom_outside_cb_t)(uint8 status);
int wifi_register_send_pkt_freedom_cb(freedom_outside_cb_t cb);
void wifi_unregister_send_pkt_freedom_cb(void);
int wifi_send_pkt_freedom(uint8 *buf, int len, bool sys_seq);
#include <ESP8266HTTPClient.h>
#include "./structures.h"
#define MAX_APS_TRACKED 100
#define MAX_CLIENTS_TRACKED 200
#define HOST "example.com" // Enter HOST URL without "http:// " and "/" at the end of URL
#define WIFI_SSID "*******" // WIFI SSID here
#define WIFI_PASSWORD "********"
int aps_known_count = 0; // Number of known APs
int nothing_new = 0;
int clients_known_count = 0; // Number of known CLIENTs
int val = 1;
int val2 = 99;
String sendval, sendval2, postData;
void wifi_upload()
pinMode(LED_BUILTIN, OUTPUT); // initialize built in led on the board
WiFi.mode(WIFI_STA);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD); //try to connect with wifi
Serial.print("Connecting to ");
Serial.print(WIFI_SSID);
while (WiFi.status() != WL_CONNECTED)
{ Serial.print(".");
Serial.print("Connected to ");
Serial.println(WIFI_SSID);
Serial.print("IP Address is : ");
Serial.println(WiFi.localIP()); //print local IP address
delay(30);
void promisc_cb(uint8_t *buf, uint16_t len)
signed potencia;
if (len == 12) {
struct RxControl *sniffer = (struct RxControl*) buf;
potencia = sniffer->rssi;
} else if (len == 128) {
struct sniffer_buf2 *sniffer = (struct sniffer_buf2*) buf;
struct beaconinfo beacon = parse_beacon(sniffer->buf, 112, sniffer->rx_ctrl.rssi);
potencia = sniffer->rx_ctrl.rssi;
struct sniffer_buf *sniffer = (struct sniffer_buf*) buf;
// Position 12 in the array is where the packet type number is located
// For info on the different packet type numbers check:
// https://stackoverflow.com/questions/12407145/interpreting-frame-control-bytes-in-802-11-wireshark-trace
// https://supportforums.cisco.com/document/52391/80211-frames-starter-guide-learn-wireless-sniffer-traces
// https://ilovewifi.blogspot.mx/2012/07/80211-frame-types.html
if ((buf[12] == 0x88) || (buf[12] == 0x40) || (buf[12] == 0x94) || (buf[12] == 0xa4) || (buf[12] == 0xb4) || (buf[12] == 0x08))
//Serial.printf("%02x\n",buf[12]);
// if(buf[12]==0x40) Serial.printf("Disconnected: ");
// if(buf[12]==0x08) Serial.printf("Data: ");
// if(buf[12]==0x88) Serial.printf("QOS: ");
// Origin MAC address starts at byte 22
// Print MAC address
// ANTHONY'S OPINION - store buf[22+i] to string variable then upload that string variable
// ANTHONY'S OPINION - do the same for the other buf[x]
for (int i = 0; i < 5; i++) {
Serial.printf("%02x:", buf[22 + i]);
Serial.printf("%02x ", buf[22 + 5]);
// Signal strength is in byte 0
Serial.printf("%i\n", int8_t(buf[0]));
wifi_upload();
HTTPClient http; // http object of class HTTPClient
// Convert integer variables to string
sendval = String(buf[22 + 5]);
sendval2 = String(buf[0]);
postData = "sendval=" + sendval + "&sendval2=" + sendval2;
// We can post values to PHP files as example.com/dbwrite.php?name1=val1&name2=val2&name3=val3
// Hence created variable postDAta and stored our variables in it in desired format
// For more detials, refer:- https://www.tutorialspoint.com/php/php_get_post.htm
// Update Host URL here:-
http.begin("http://192.168.0.31/arduino_trial/dbwrite.php"); // Connect to host where MySQL databse is hosted
http.addHeader("Content-Type", "application/x-www-form-urlencoded"); //Specify content-type header
int httpCode = http.POST(postData); // Send POST request to php file and store server response code in variable named httpCode
Serial.println("Values are, sendval = " + sendval + " and sendval2 = " + sendval2 );
// if connection eatablished then do this
if (httpCode == 200) {
Serial.println("Values uploaded successfully."); Serial.println(httpCode);
String webpage = http.getString(); // Get html webpage output and store it in a string
Serial.println(webpage + "\n");
// if failed to connect then return and restart
else {
Serial.println("Failed to upload values. \n");
http.end();
return;
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(LED_BUILTIN, HIGH);
// Enable this lines if you want to scan for a specific MAC address
// Specify desired MAC address on line 10 of structures.h
/*int same = 1;
for(int i=0;i<6;i++)
if(buf[22+i]!=desired[i])
same=0;
if(same)
//different device
//Different packet type numbers
I uploaded the code successfully. However, the detection part worked but the uploading to PHP script part did not work. How do I fix this?
