I have this SNMP working over WiFi.
https://github.com/fusionps/Arduino_SNMP/blob/master/examples/SNMP_TRAP/SNMP_TRAP.ino
My question is can this be easily converted to work over Ethernet?
Does anyone have any ideas or code to share?
I have a WIZ 5500 board connected like this:
I added the WIZ code:
void WizReset() {
Serial.println("Starting Wiz W5500 Ethernet...");
pinMode(RESET_P, OUTPUT);
digitalWrite(RESET_P, HIGH);
delay(250);
digitalWrite(RESET_P, LOW);
delay(50);
delay(350);
WizReset();
- Network configuration - all except the MAC are optional.
- IMPORTANT NOTE - The mass-produced W5500 boards do -not-
- have a built-in MAC address (depite
- comments to the contrary elsewhere). You
- -must- supply a MAC address here.
Ethernet.begin(eth_MAC, eth_IP, eth_DNS, eth_GW, eth_MASK);
delay(200);
Serial.print("Ethernet IP is: ");
Serial.println(eth_IP);
Serial.print("Ethernet local IP is: ");
Serial.println(Ethernet.localIP());
And tried changing this with no luck so far.
WiFiUDP udp; TO ethernetUDP udp;
Thanks
