I do not have much notion with arduino, but I'm creating a project that needs to send the exact time for the arduino by an NTP server and parallel to that, I want to monitor an electrical signal with SNMP, however, the Agentuino library is in conflict with the NTP server , Because both have the same UDP library, then the program informs that it is having duplicity, in front of this, I would like to know if anyone has any information on how to act in this situation, if it could take from the Agentuino library the UDP library (would be quite complicated ) Or if it should be removed from the NTP server.
I don't know about that library, but with the Arduino library, you can start two instances of the UDP library.
// in global
EthernetUDP NTPUdp;
EthernetUDP Udp;
unsigned int NTPport = 8888;
unsigned int UDPport = 8886;
// in setup
NTPUdp.begin(NTPport);
Udp.begin(UDPport);
