SNMP - we can´t compile Agentuino proyect Arduino 1.0. HELP !
Hello, Can yo help us?
with the new Arduino 1.0 I can´t compile the SNMP proyect called Argentuino:
\arduino-1.0\libraries\Agentuino\Agentuino.cpp: In member function 'SNMP_API_STAT_CODES AgentuinoClass::begin()': \arduino-1.0\libraries\Agentuino\Agentuino.cpp:39: error: 'Udp' was not declared in this scope \arduino-1.0\libraries\Agentuino\Agentuino.cpp: In member function 'SNMP_API_STAT_CODES AgentuinoClass::begin(char*, char*, uint16_t)': \arduino-1.0\libraries\Agentuino\Agentuino.cpp:63: error: 'Udp' was not declared in this scope \arduino-1.0\libraries\Agentuino\Agentuino.cpp: In member function 'void AgentuinoClass::listen()': \arduino-1.0\libraries\Agentuino\Agentuino.cpp:73: error: 'Udp' was not declared in this scope \arduino-1.0\libraries\Agentuino\Agentuino.cpp: In member function 'SNMP_API_STAT_CODES AgentuinoClass::requestPdu(SNMP_PDU*)': \arduino-1.0\libraries\Agentuino\Agentuino.cpp:98: error: 'Udp' was not declared in this scope \arduino-1.0\libraries\Agentuino\Agentuino.cpp: In member function 'SNMP_API_STAT_CODES AgentuinoClass::responsePdu(SNMP_PDU*)': \arduino-1.0\libraries\Agentuino\Agentuino.cpp:350: error: 'Udp' was not declared in this scope
Can anybody help us with this. We need a SNMP proyect running with Arduino that we can use.
Hi.
I've had some success, but some testing remains.
See my posts at http://code.google.com/p/agentuino/issues/detail?can=2&start=0&num=100&q=&colspec=ID%20Type%20Status%20Priority%20Milestone%20Owner%20Summary&groupby=&sort=&id=2
Regards Alf Solli
