Hello,
I am trying to use the newly released Microsoft Azure IOT library.
There is a line in the initial sketch which I have modified heavily that states.
// replace the following line with your data sent to Azure IoTHub
snprintf(buff, 128, "{\"topic\":\"iot\"}");
I have tried to replace this with
snprintf(buff, 128, "{\"" + MQTTTopic + "\":\"" + MQTTPayload + "\"}");
Which is erroring on compilation.
error: cannot convert 'StringSumHelper' to 'const char*' for argument '3' to 'int snprintf(char*, size_t, const char*, ...)'
I have never used snprint before and I am wanting to insert string values (MQTTTopic & MQTTPayload).
Is there a better way to do this and can someone please help me here.
Thanks in advance
Shane Baldacchino
Hi
I'm not a software expert, but try it like this:
snprintf(buff, 128, "{\" + MQTTTopic + \":\" + MQTTPayload + \"}");
The snprintf() function is used with C-strings (zero terminated character arrays).
Don't use it with String objects.
When contemplating the use of a new function, it is an outstandingly good idea to study the reference guide!
https://www.cplusplus.com/reference/cstdio/snprintf/
J-M-L
December 26, 2021, 9:52pm
4
If you really want to use a String then just concat the data in a new string
String tempString;
tempString.reserve(60);
tempString = String("{\"") + MQTTTopic + String("\":”) + MQTTPayload + String("}");
And then your cString buffer you want to send is in
tempString.c_str()
@jremington
From reading it looks like it is expecting a fixed character string I need to read up more on this
@J-M-L - Thank-you, you helped me a few months ago and appreciate you working around my capabilities. Your code snippet works a charm. Thank-you!
system
Closed
June 24, 2022, 10:12pm
6
