snprintf - appears to be operating in a wierd manner
Hi, I am using IDE 1.6.9 (under Windows 10) and found the problem in a complex sketch loaded onto a Mega 2560. I then ported a subset of code (minimalised and simplistic) onto a Uno which also demonstrates the problem.
This sketch is shown below and has a group of snprintf() calls at the end, only one of which is active at any given time ( in order to diagnose the problem)
const size_t sizeBuffer = 140;
char g_szBuffer[sizeBuffer];
  snprintf(g_szBuffer,sizeBuffer,"Hello world");
  Serial.print(F("Contents of g_szBuffer after initialization [prior to sendEmail()] is :")); Serial.println(g_szBuffer);    //... which is correct i.e. "Hello again"
  sendEmail(g_szBuffer);
byte sendEmail(const char szTextIn[])    // 20190930
  Serial.println("In Sendmail");
  Serial.print(F("szTextIn :")); Serial.println(szTextIn);
  Serial.print(F("g_szBuffer before initialisation [in sendEmail] :")); Serial.println(g_szBuffer);
  int iRet = 0;
  snprintf(g_szBuffer,sizeBuffer,"**** Connection failed (msg is %s) - return code = %i",szTextIn,iRet);    //original
  //Original result: "**** Connection failed (msg is **** Connection failed (msg is ) - return code = 0"
  //snprintf(g_szBuffer,sizeBuffer,"msg is %s - return code = %i",szTextIn,iRet);
  // TEST 1  result: "msg is msg is msg  - return code = 0"
  //snprintf(g_szBuffer,sizeBuffer," %s - return code = %i",szTextIn,iRet);
  // TEST 2  result: "             - return code = 0"
  //snprintf(g_szBuffer,sizeBuffer,"%s - return code = %i",szTextIn,iRet);
  // TEST 3  result: "Hello world - return code = 0"     AS EXPECTED
  Serial.println(F("Result of snprintf() ... "));
  return 0;
The serial monitor output for the "original" snprintf() is shown below:
Contents of g_szBuffer after initialization [prior to sendEmail()] is :Hello world
In Sendmail
szTextIn :Hello world
g_szBuffer before initialisation [in sendEmail] :Hello world
The "error" is that the text preceeding the %s appears to be repeated insted of the %s rather than szTextIn.
For convenience, I have annotated the result of each test below the appropriate snprintf() call, rather than showing multiple SM.
I have also found that correct operation occurs if the target of the snprintf is a local var to the function sendEmail() rather than the current global var g_szBuffer.
I just don't understand what is happening here as I believe that my usage of snprintf() is correct
So you’re doing essentially
snprintf(buf, Len, “%s”, buf);
With the destination being the same as one of the strings you’re printing?
I don’t know whether that’s supposed to be legal, but it sure doesn’t sound “safe”!
westfw:
Hi, I don't follow you ? (or am I missing something ?)
So I am printing to the destination g_szBuffer with %s loading a string from szTextIn. Yes ?
Yes, but szTextIn is g_szBuffer:
oqibidipo:
Ahhhhhhhhhhhhh !! Got you !! What a plonker !!!
Many thanks to both !!
