MarkT:
The SNS0 and SNS1 pins don't measure voltage, they measure the current to each motor. Is that what you meant?
I did mean voltage but I should be measuring the current across the motors. Thanks.
My plan is to have the Robotic Car change directions when the motor stalls do to an obstacle in the way. I want to measure the current across the motor so that when it stalls and current increases it will change directions. I've uploaded a video to http://youtu.be/yTfU8XdpGds so that you can see what I am doing.
Would this ( http://arduino.cc/en/Tutorial/Smoothing ) be a good code to modify for the average?
I powering the arduino motor shield with 6 AA batteries which is in turn powering the arduino. I am not powering the arduino separate from the motors.
Should it be? Because it can be.
Here is the complete code. Sorry about some of the comments. I am still new to arduino. Any help you can give me is appreciated.
#include <NewPing.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define TRIGGER_PIN 7
#define ECHO_PIN 6
#define MAX_DISTANCE 176
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
/*-----( Declare Variables )-----*/
int DistanceCm = 0;
int opto = 2; //controls servo power which prevents it from humming
int opto2 = 10; //controls lights
int opto3 = 5; //controls lights
int times = 1;
int time = 1;
const int analog0 = A0; //subtract ambient analog noise
const int analog1 = A1; // Analog input pin that the potentiometer is attached to
int sensorVal = 0;
//servo setup
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int pos = 0; // variable to store the servo position
myservo.attach(4); // attaches the servo on pin 9 to the servo object
pinMode(13, OUTPUT); //Initiates Motor Channel B pin
pinMode(8, OUTPUT); //Initiates Brake Channel B pin
pinMode(opto, OUTPUT);
pinMode(opto2, OUTPUT);
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
servoset(85,800); //servo faces forward
if (times == 1) {
servoset(85,700);
times = 0;
} //turn off servo set after first read, I will reset position later
servoread (); //reading the sonar and returning value as distanceCm
int x = DistanceCm; //I like x it is easier to type
x = map(x , 0 , 177, 0, 160); //mapping the values because the greates distance is about 177 read by the cheap servo
if (x==0){
x = 160;
} //out of range value is normally 0 but because I mapped it at 1 I made it equal to 160 because I want to control the motor speed with these values
carmovement (132);
digitalWrite(opto2, LOW);
analogWrite(opto3, 0);
sensorRead ();
//Serial.print(x); Serial.println(" cm"); // I want to see what is going on to debug
Serial.print(sensorVal);
Serial.println(" motor"); // I want to see what is going on to debug
while (x < 30)
digitalWrite(opto2, HIGH);
analogWrite(opto3, 255);
carstop(1000);
servoset(185,800); //servo is turning left direction
servoread (); //reading with ping sensor
int xl = DistanceCm;
xl = map(xl , 0 , 177, 0, 160);
if (xl==0){
xl = 160;
//Serial.print(xl);
//Serial.println(" left");
servoset(0,900); //servo is turning right direction
int xr = DistanceCm;
xr = map(xr , 0 , 177, 0, 160);
if (xr==0){
xr = 160;
//Serial.print(xr);
//Serial.println(" right");
if (xl < 40 && xr > xl) // if the left distance is less than 40cm and the right distance is greater than the left
servoread (); //read the ping
int x = DistanceCm; //intialize x again
while (x < 20) //while the forward distance is less than 20
carmovement(-2); //car will reverse for specified distance
break; // then break the while loop
carbackright(); // car will back up and go right because left is blocked
digitalWrite(8, HIGH); //Engage the Brake for Channel B
//Serial.print("carturnright"); // to debug is serial screen
break; //break the while loop
if (xr < 40 && xr < xl)
servoread ();
int x = DistanceCm;
while (x < 20)
carmovement(-113); //reverse for specified distance
break;//break the while loop
carbackleft();
//Serial.print("carturnleft");
if (xl > 40 && xr > 40)
servoread ();
int x = DistanceCm;
while (x < 20)
carmovement(-113);
carstop(100);
carbackleft();
if (sensorVal > 230 ) {
carbackright ();
if (//sensorValue < 10 &&
time == 1)
{//carbackright ();
time = 2;
return;
time == 2)
{//carbackleft ();
time = 1;
return;
void servoset(int x, int y)
digitalWrite(opto, HIGH);
myservo.write(x);
delay(y);
digitalWrite(opto, LOW);
int servoread ()
delay(32);// Wait 100ms between pings (about 10 pings/sec). 29ms should be the shortest delay between pings.
DistanceCm = sonar.ping_cm();
return (DistanceCm);
int sensorRead ()
int sensorVal0 = analogRead(analog0);
delay (10);
int sensorVal1 = analogRead(analog1);
int sensorValold = (sensorVal0 + sensorVal1)/2;
delay (10);
int sensorVal2 = analogRead(analog0);
delay (10);
int sensorVal3 = analogRead(analog1);
int sensorValnew = (sensorVal2 + sensorVal3)/2;
sensorVal = (sensorValnew + sensorValold)/2;
void carback(int x)
digitalWrite(12, LOW); //Establishes backward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
analogWrite(3, x); //Spins the motor on Channel A at half speed
void carmovement (int x)
if (x > 0)
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
analogWrite(3, x); //Spins the motor on Channel A at full speed
delay(10);
if (x < 0)
analogWrite(3, -x); //Spins the motor on Channel A at half speed
delay(10);
int carstop (int t)
digitalWrite(8, HIGH); //Eengage the Brake for Channel B
digitalWrite(9, HIGH); //Eengage the Brake for Channel A
delay (t);
void carbackleft ()
digitalWrite(13, HIGH); //left
digitalWrite(8, LOW); //Disengage the Brake for Channel B
analogWrite(11, 255); //Spins the motor on Channel B at full speed
delay (100);
analogWrite(3, 145); //Spins the motor on Channel A at half speed
delay (2000);
carstop(10);
digitalWrite(13, LOW); //right
analogWrite(11, 255); //Spins the motor on Channel B at half speed
delay (100);
analogWrite(3, 145); //Spins the motor on Channel A at full speed
delay (1700);
carstop(10);
void carbackright ()
delay (100);
analogWrite(3, 135); //Spins the motor on Channel A at half speed
delay (2000);
carstop(10);
delay (100);
analogWrite(3, 125); //Spins the motor on Channel A at full speed
delay (1700);
carstop(10);
