Ok so basically I have an MPU6050 unit and I wanna use this exampe however I wanna turn it into a class with methods I can just call. As you can see theres already a class called MPU6050 but I wanna have that class include all these variables and have additional methods such as a setupMPU() method thats just
void MPU::setupMPU(){
Wire.begin();
Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
while (!Serial);
// initialize device
Serial.println(F("Initializing I2C devices..."));
initialize();
// verify connection
Serial.println(F("Testing device connections..."));
Serial.println(testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
// wait for ready
Serial.println(F("\nSend any character to begin DMP programming and demo: "));
while (Serial.available() && Serial.read()); // empty buffer
while (!Serial.available()); // wait for data
while (Serial.available() && Serial.read()); // empty buffer again
// load and configure the DMP
Serial.println(F("Initializing DMP..."));
devStatus = dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
setXGyroOffset(220);
setYGyroOffset(76);
setZGyroOffset(-85);
setZAccelOffset(1788); // 1688 factory default for my test chip
// make sure it worked (returns 0 if so)
if (devStatus == 0) {
// Calibration Time: generate offsets and calibrate our MPU6050
CalibrateAccel(6);
CalibrateGyro(6);
PrintActiveOffsets();
// turn on the DMP, now that it's ready
Serial.println(F("Enabling DMP..."));
setDMPEnabled(true);
dmpReady = true;
// get expected DMP packet size for later comparison
packetSize = dmpGetFIFOPacketSize();
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
Trying to make my header file look look like this, notice that my class inherits from the main class
#ifndef MPU_H
#define MPU_H
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
#include <Arduino.h>
class MPU : public MPU6050 {
private:
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
public:
void setupMPU(); // Wakes up MPU and gets it ready for reading data.
void setData(); // Sets yaw pitch and roll
#endif
However after doing this the code throws too many errors and most of them are like "this method was previously declared" kinda errors and I honestly have no clue why its like that. in my sketch i only include "mpu.h" which is my header file. All the other includes are in the header itself
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:176:6: note: 'setExternalFrameSync' was previously declared here
void MPU6050::setExternalFrameSync(uint8_t sync) {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:176:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:460:14: warning: 'setDLPFMode' violates the C++ One Definition Rule [-Wodr]
void setDLPFMode(uint8_t bandwidth);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:219:6: note: implicit this pointer type mismatch
void MPU6050::setDLPFMode(uint8_t mode) {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.h:441:7: note: type 'struct MPU6050' itself violates the C++ One Definition Rule
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:441:7: note: the incompatible type is defined here
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:219:6: note: 'setDLPFMode' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:219:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:464:14: warning: 'setFullScaleGyroRange' violates the C++ One Definition Rule [-Wodr]
void setFullScaleGyroRange(uint8_t range);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:254:6: note: implicit this pointer type mismatch
void MPU6050::setFullScaleGyroRange(uint8_t range) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:254:6: note: 'setFullScaleGyroRange' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:254:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:816:14: warning: 'writeProgMemoryBlock' violates the C++ One Definition Rule [-Wodr]
bool writeProgMemoryBlock(const uint8_t *data, uint16_t dataSize, uint8_t bank=0, uint8_t address=0, bool verify=true);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3161:6: note: implicit this pointer type mismatch
bool MPU6050::writeProgMemoryBlock(const uint8_t *data, uint16_t dataSize, uint8_t bank, uint8_t address, bool verify) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3161:6: note: 'writeProgMemoryBlock' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3161:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:815:14: warning: 'writeMemoryBlock' violates the C++ One Definition Rule [-Wodr]
bool writeMemoryBlock(const uint8_t *data, uint16_t dataSize, uint8_t bank=0, uint8_t address=0, bool verify=true, bool useProgMem=false);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3085:6: note: implicit this pointer type mismatch
bool MPU6050::writeMemoryBlock(const uint8_t *data, uint16_t dataSize, uint8_t bank, uint8_t address, bool verify, bool useProgMem) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3085:6: note: 'writeMemoryBlock' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3085:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:823:14: warning: 'setDMPConfig1' violates the C++ One Definition Rule [-Wodr]
void setDMPConfig1(uint8_t config);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3250:6: note: implicit this pointer type mismatch
void MPU6050::setDMPConfig1(uint8_t config) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3250:6: note: 'setDMPConfig1' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3250:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:827:14: warning: 'setDMPConfig2' violates the C++ One Definition Rule [-Wodr]
void setDMPConfig2(uint8_t config);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3260:6: note: implicit this pointer type mismatch
void MPU6050::setDMPConfig2(uint8_t config) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3260:6: note: 'setDMPConfig2' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3260:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:734:14: warning: 'setOTPBankValid' violates the C++ One Definition Rule [-Wodr]
void setOTPBankValid(bool enabled);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2835:6: note: implicit this pointer type mismatch
void MPU6050::setOTPBankValid(bool enabled) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2835:6: note: 'setOTPBankValid' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2835:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:497:14: warning: 'setMotionDetectionThreshold' violates the C++ One Definition Rule [-Wodr]
void setMotionDetectionThreshold(uint8_t threshold);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:532:6: note: implicit this pointer type mismatch
void MPU6050::setMotionDetectionThreshold(uint8_t threshold) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:532:6: note: 'setMotionDetectionThreshold' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:532:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:505:14: warning: 'setZeroMotionDetectionThreshold' violates the C++ One Definition Rule [-Wodr]
void setZeroMotionDetectionThreshold(uint8_t threshold);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:602:6: note: implicit this pointer type mismatch
void MPU6050::setZeroMotionDetectionThreshold(uint8_t threshold) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:602:6: note: 'setZeroMotionDetectionThreshold' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:602:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:501:14: warning: 'setMotionDetectionDuration' violates the C++ One Definition Rule [-Wodr]
void setMotionDetectionDuration(uint8_t duration);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:562:6: note: implicit this pointer type mismatch
void MPU6050::setMotionDetectionDuration(uint8_t duration) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:562:6: note: 'setMotionDetectionDuration' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:562:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:509:14: warning: 'setZeroMotionDetectionDuration' violates the C++ One Definition Rule [-Wodr]
void setZeroMotionDetectionDuration(uint8_t duration);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:633:6: note: implicit this pointer type mismatch
void MPU6050::setZeroMotionDetectionDuration(uint8_t duration) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:633:6: note: 'setZeroMotionDetectionDuration' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:633:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:682:14: warning: 'setFIFOEnabled' violates the C++ One Definition Rule [-Wodr]
void setFIFOEnabled(bool enabled);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2352:6: note: implicit this pointer type mismatch
void MPU6050::setFIFOEnabled(bool enabled) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2352:6: note: 'setFIFOEnabled' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2352:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:803:14: warning: 'resetDMP' violates the C++ One Definition Rule [-Wodr]
void resetDMP();
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3026:6: note: implicit this pointer type mismatch
void MPU6050::resetDMP() {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3026:6: note: 'resetDMP' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3026:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:802:14: warning: 'setDMPEnabled' violates the C++ One Definition Rule [-Wodr]
void setDMPEnabled(bool enabled);
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3023:6: note: implicit this pointer type mismatch
void MPU6050::setDMPEnabled(bool enabled) {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3023:6: note: 'setDMPEnabled' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:3023:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:686:14: warning: 'resetFIFO' violates the C++ One Definition Rule [-Wodr]
void resetFIFO();
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2392:6: note: implicit this pointer type mismatch
void MPU6050::resetFIFO() {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2392:6: note: 'resetFIFO' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:2392:6: note: code may be misoptimized unless -fno-strict-aliasing is used
D:\Folders\Documents\Arduino\libraries\MPU6050\src/MPU6050.h:618:17: warning: 'getIntStatus' violates the C++ One Definition Rule [-Wodr]
uint8_t getIntStatus();
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:1688:9: note: implicit this pointer type mismatch
uint8_t MPU6050::getIntStatus() {
class MPU6050 {
class MPU6050 {
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:1688:9: note: 'getIntStatus' was previously declared here
D:\Folders\Documents\Arduino\libraries\MPU6050\src\MPU6050.cpp:1688:9: note: code may be misoptimized unless -fno-strict-aliasing is used
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Nano.
I realize now that most of these are warnings that i got when the example worked before without the OOP however theres an error at the end there not allowing me to complie which I didnt get before and I cant trace where it happens
