So Many Options!
I wondered of any of you could help me please as i'm having trouble selecting what board i need.
I need two separate mini motors, a mini air pump (Both 6V) and two leds to be controlled separately with different timings.
What simple and cheep board can I use that will let me adjust the duration of the motor/Airpump independently and change the voltage to slow the output down.
Thanks allot,
Josh.
Promini.
Control a N-channel MOSFET to PWM the output for each device to slow it down. Do not change voltage to do it.
AOI508 would be good.
The Pro Mini is great but I don't recommend it to people just starting out. It requires a separate programmer.
The UNO is the best to start with, although it's rather large for many projects. A Nano or Micro is very good. If you must have it cheap, then buy a clone on your favourite auction site.
The basic Arduino Uno has 14 general purpose I/O pins, and from what you've said you only need 4 outputs. Any inputs? (Switches/controls. etc?)
Of course, you can read/write the I/O pins independently ( [u]digitalWrite()[/u] or [u]analogWrite()[/u] ).
Note that analogWrite() isn't true analog. It's PWM, but that will work to dim and LED or to control the speed of a motor.
You can directly drive LEDs (through a current-limiting resistor) but the Arduino can't put-out enough current to drive a motor so you'll need a transistor or MOSFET [u]driver circuit[/u] for each motor (and a 6V source).
Depending on your timing requirements you may need to set-up multiple timers. See [u]Demonstration code for doing server things at the same time[/u] at the top of the forum.
I'm only 16 and i'm starting to take an interest in electronics, learning new stuff everyday!
I'll Have a look at some videos on YouTube but i think from your recommendations I'll use a arduino uno.
Thank you so much guys for all the help. Most appreciated!
Josh.
Best all around: Nano
Cheapest: Pro Mini
For use with a shield: Uno
To emulate keyboard or mouse: Pro Micro
To emulate keyboard or mouse and use shields: Leonardo
More pins and memory: Mega
I recommend only using Pro Micro or Leonardo if you need the keyboard/mouse emulation features. Those boards are not as user friendly as the regular Arduinos.
Better description:
"The basic Arduino Uno has 14 20 general purpose I/O pins," 6 of which can also do analog reads, and 6 others which can support hardware 'set & forget' PWM outputs.
"The Pro Mini is great but I don't recommend it to people just starting out. It requires a separate programmer USB/serial interface adapter**."**
