I recently discovered the power of Streaming.h.
I would like to use this coding methodology to drive my hd44780.
Is it possible?
I have seen also various streamer for printing.
I question myself on redundancy.
as long as the LCD library inherits from Print.h - it will work for Streaming.h.
Most of the LCD libraries inherit from Print.h.
I never thought of doing that, so I gave it a try. The modified example works in my basement.
#include <Streaming.h>
// vi:ts=4
// HelloWorld - simple demonstration of lcd
// Created by Bill Perry 2016-07-02
// bperrybap@opensource.billsworld.billandterrie.com
// This example code is unlicensed and is released into the public domain
// This sketch is for LCDs with PCF8574 or MCP23008 chip based backpacks
// WARNING:
// Use caution when using 3v only processors like arm and ESP8266 processors
// when interfacing with 5v modules as not doing proper level shifting or
// incorrectly hooking things up can damage the processor.
// Sketch prints "Hello, World!" on the lcd
// If initialization of the LCD fails and the arduino supports a built in LED,
// the sketch will simply blink the built in LED.
// NOTE:
// If the sketch fails to produce the expected results, or blinks the LED,
// run the included I2CexpDiag sketch to test the i2c signals and the LCD.
// LiquidCrystal compability:
// Since hd44780 is LiquidCrystal API compatible, most existing LiquidCrystal
// sketches should work with hd44780 hd44780_I2Cexp i/o class once the
// includes are changed to use hd44780 and the lcd object constructor is
// changed to use the hd44780_I2Cexp i/o class.
#include <Wire.h>
#include <hd44780.h> // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
hd44780_I2Cexp lcd; // declare lcd object: auto locate & auto config expander chip
// If you wish to use an i/o expander at a specific address, you can specify the
// i2c address and let the library auto configure it. If you don't specify
// the address, or use an address of zero, the library will search for the
// i2c address of the device.
// hd44780_I2Cexp lcd(i2c_address); // specify a specific i2c address
// It is also possible to create multiple/seperate lcd objects
// and the library can still automatically locate them.
// Example:
// hd4480_I2Cexp lcd1;
// hd4480_I2Cexp lcd2;
// The individual lcds would be referenced as lcd1 and lcd2
// i.e. lcd1.home() or lcd2.clear()
// It is also possible to specify the i2c address
// when declaring the lcd object.
// Example:
// hd44780_I2Cexp lcd1(0x20);
// hd44780_I2Cexp lcd2(0x27);
// This ensures that each each lcd object is assigned to a specific
// lcd device rather than letting the library automatically asign it.
// LCD geometry
const int LCD_COLS = 16;
const int LCD_ROWS = 2;
int status;
// initialize LCD with number of columns and rows:
// hd44780 returns a status from begin() that can be used
// to determine if initalization failed.
// the actual status codes are defined in <hd44780.h>
// See the values RV_XXXX
// looking at the return status from begin() is optional
// it is being done here to provide feedback should there be an issue
// note:
// begin() will automatically turn on the backlight
status = lcd.begin(LCD_COLS, LCD_ROWS);
if(status) // non zero status means it was unsuccesful
// hd44780 has a fatalError() routine that blinks an led if possible
// begin() failed so blink error code using the onboard LED if possible
hd44780::fatalError(status); // does not return
// initalization was successful, the backlight should be on now
// Print a message to the LCD
// lcd.print("Hello, World!");
lcd <<"Stream World!";
void loop() {}
Thank you.
Very promising approach for LCDs.
How can we use this methodology when creating (and later exporting) a .csv file for feeding a spreadsheet ?
exactly the same.
If you can print you your spreadsheet/CSV using print,
you can use streaming also.
Thanks to all. You helped me to document a little about streaming.
LCD_and_streaming.pdf (2.1 MB)
From the PDF...
The sequence of the fields is not kept. I suspect that the logic inside the LCD is the guilty because the streaming output for serial is correct.
You are correct. In the 4 line displays the addresses for the lines are treated as two sets that end up interleaved.
line 1
line 3
line 2
line 4
