i dont understand why this doesnt show anything
int x=30;
void setup(){
void loop(){
Serial.print(x);
why it doesnt print 30 in the serial?
int x=30;
void setup(){
void loop(){
Serial.print(x);
void setup(){
Hum
Serial.begin(9600); //set the serial transfer rate. Serial Monitor at a data rate of 9600 bits per second.
Why didn't you first use the Serial.begin(9600); function?
Use this code -
int x = 30;
void setup(){
void loop(){
Serial.print(x);
(deleted)
Yep - First time posters you can perhaps make allowances for, but for someone with 60 posts...
Like this...
[code]//some code here[/code]
When posted on the forum appear like this...
//some code here
There's even the </> button on the toolbar to insert the tags automatically for you...
Perhaps the forum should disallow posts containing {} unless they are inside code tags. Bring up a warning instead "Did you mean to use code tags?".
