Hi guys,
I'm a trying to connect my Arduino Uno from my notebook and when I tried to monitor all the digital outputs using flash I've received this message: Connection with Serproxy established. Socket closed!
This is my serproxy config: ( COM4 is detected by my Arduino )
Config file for serproxy - PC Version
Do not Transform newlines coming from the serial port into nils
newlines_to_nils=false
Comm ports used
comm_ports=4
Default settings
comm_baud=9600
comm_databits=8
comm_stopbits=1
comm_parity=none
Idle time out in seconds
timeout=300
Settings for COM3
net_port4=5331
Mac OSX: You'll have to change the line serial_device1=... and insert the name of the usbserial device you found in the previous step.
Comm ports used
comm_ports=4
Default settings
comm_baud=9600
comm_databits=8
comm_stopbits=1
comm_parity=none
timeout=300
#serial_device1=/dev/cu.usbserial-A1001NgZ
#net_port1=5331
Note: my machine use Windows 7
Somebody could help my to establish the connection?
